09-23-2019, 12:44 AM | #1 |
Rep 70
Mixing Front/Rear Tire Brands
Hi,
Sorry if this is a dumb question but I've never had run flats before...I picked up a used 228i and while checking tread depth I didn't think to check manufacturers- my 18" wheels have Bridgestones on the rears and Pirelli on the fronts (I want to say 245 rear and 225 front). I'm RWD. Is this something I should worry about? Don't have the exact models handy but can grab in a bit. Traction has been fine in the week I've had it, feel more road than I'm used to but I've been told that's just RFT's in general. Car has 19k on it so I'm assuming 2 of them must be new-ish. |
09-23-2019, 06:50 AM | #2 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
Don't need to worry about mixing tire manufacturers. As long as they are the right tires for the season and correct sizes, you will be fine. Don't run summer only tires in the middle of a snow storm, don't run 225/40 front with 245/30 in the rear (factory is 225/40/18 front 245/35/18 rear if I'm not mistaken).
staticcornflake13.50 |
09-23-2019, 12:51 PM | #3 |
Rep 410
Mixed sets are not ideal as for aquaplaning, dry grip, road holding there now could be differences between the front and rear set.
But is they are in same category high performance all season / ultra high performance summer / ..... the differences should be relatively small. Just make sure you don't have a touring on one axle and ultra high performance on the other as that might result in very exiting handling in emergency situations. |
09-24-2019, 04:26 PM | #5 |
Rep 566
At least now you know what happened to the car before you - front wheel damage
This particular combo shouldn't be a problem as long as you go in straight lines and don't push it. Pirellis are wider than the same-sized Bridgestones. Could be a problem in emergency or close to the limit, as in sharp turns, when tires cold, etc., the rear is more likely to let go earlier and more abruptly, snap overstreer, etc. |
09-24-2019, 08:22 PM | #6 | |
Rep 70
I like straight lines but also want to have some fun with the car on canyons and such - should I match the tires all up? I'm sure it would be futile, but worth going back to the BMW dealer and calling shenanigans on this? |
09-25-2019, 04:14 PM | #7 | |
Rep 566
There are people who know this stuff and can tell from inspecting the vehicle if and just how bad the actual damage was, body work, damaged/replaced shocks, alignment, etc... no one can't exactly replicate the factory paint, welding, etc. If there was some body work performed on the vehicle they'd be able to tell. So if in doubt you could probably find some professional to look at it. The dealership... maybe they could at least have an uncomfortable moment when confronted with this. Matching the tires - I'd do it. I actually like non-runflat P Zeros and I'd use them 245/35/18 in the rear (oem size), and if no signs of a more serious damage were detected I'd just be happy with it. |
09-25-2019, 05:46 PM | #8 | |
Rep 70
