2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack 18x9??
      09-17-2019, 11:22 AM   #1
BelugaaF22
BelugaaF22's Avatar
Drives: 228i N20
18x9??
Hi all,
I browse the forum a lot but dont post a lot. I apologize if this has been brought up before but I could not find anything in the search. Can a stock 228i fit 18x9 or 18x9.5 (with spacers) wheels? if so, what is the max tire size I can run?
Also alternatively, what is the max tire size I can comfortably run on the stock M-staggered setup? Thanks in advance!
      09-17-2019, 11:56 AM   #2
MarkDemma
MarkDemma's Avatar
This is what I put on my M240i and they fit just fine:
BEYERN RITZ Gloss Gunmetal with Brushed Face (18" x 8.5", +35 Offset, 5x120.65 Bolt Pattern, 72.6mm Hub)
PILOT SPORT 4S Tires by Michelin®. 225/40ZR18
BEYERN RITZ Gloss Gunmetal with Brushed Face (18" x 9.5", +45 Offset, 5x120.65 Bolt Pattern, 72.6mm Hub)
PILOT SPORT 4S Tires by Michelin®. 255/35ZR18
      09-17-2019, 12:51 PM   #3
marcthedark
Drives: M240i xdrive Convertible
On stock staggered rims? 225/40 and 245/35 or (possible but outside tire manufacturers guidelines) 235/40 front and 255/35 back
      09-19-2019, 12:53 PM   #4
BelugaaF22
BelugaaF22's Avatar
Drives: 228i N20
thanks both for your responses.
the 228i and m240 should have the same wheel configuration though right? (as in if it fits in a m240, it should fit in a 228i?)
also, thoughts on putting a 275/35 on the rear with 18x9.5 wheels?
      09-20-2019, 01:20 PM   #5
230iZTR
230iZTR's Avatar
316
You'll rub. 265s on an 9.5J et50-53 rim are the max you can run in the rear due to the narrow fender and gas filler neck. You could go wider with cut and flared fenders and relocating the fuel cap and neck (like the m235iR and m240iR racecars) but that's a lot of work for just another 10mm.
      09-20-2019, 05:13 PM   #6
BelugaaF22
BelugaaF22's Avatar
Drives: 228i N20
thanks, this helps.
Cheers
