07-26-2017, 02:18 PM | #1 |
Rep 26
How many miles did your n55 live before rebuild?
What is the average mileage of N55 on m235 before rebuild? Heard the engine runs at very high water and oil temperature, does it affect its mileage?
07-27-2017, 09:10 AM | #3 |
Rep 2,214
All of the newer engines run hot, including the M2/3/4 variants. It does not equate to needing a rebuild, though? These aren't engines I would be concerned of in terms of reliability and durability in any case, they're pretty stout and should have a great long life cycle.
07-27-2017, 11:30 AM | #5 |
Rep 2,214
07-28-2017, 11:03 AM | #7 |
Rep 1,422
I've got 15,800 miles on mine and already had 5 oil changes. After PS2, I've shortened the interval to 3K miles and started using LiquiMoly oil.
07-28-2017, 03:37 PM | #8 |
Rep 350
M235 hasn't been out long enough for people to start doing engine rebuilds from mileage failure, let alone enough people doing them to get any sort of statistically relevant 'average'
07-29-2017, 11:42 AM | #14 |
Rep 2,214
Since I started running meth, I've noticed all of my exhaust is looking brand new, like whatever carbon residue was inside the tailpipes are gone! It looks like I spent a day cleaning/polishing the inside of the exhaust. Curious if this aids in any prevention from the long term carbon buildup seen on DI engines? I know the N55 solved a lot of that, along with oil blow by, etc, but I'm curious if there is any REAL benefit aside from the power gains?
11-07-2018, 11:10 AM | #15 |
Rep 7
11-09-2018, 11:45 AM | #16 |
Rep 9,004
09-02-2019, 03:11 PM | #17 | |
Rep 294
Why not change it with every refuel maybe? |
09-03-2019, 02:56 AM | #18 |
Rep 373
Im doing oil changes every 5000km because i race car a daily
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
06-14-2021, 08:46 AM | #19 |
Newbie
Rep 29
m235i-ZF8-RWD owner here with 129k+ KM daily driver with 45c 4 months summer temperatures and 90% humidity in Saudi Arabia Jeddah. (hard driver at the first couple years, normal driver to occasionally hard the last couple years)
the issues i remember i ran to are: + wiper fluid motor failed. + battery replaced once. + front fender Paint job from small bumps. below are annoying issues (with no damage) so far by the following but might be immanent to a problem coming: + weird squeek sound on the right front dash (almost sounds from the corner or door) only on slow speeds and uneven road, got it fixed 1st time by the dealer and went away by replacing few parts, 8months later same exact sound comes back slowly, got it fixed by dealer again with more parts replaced, issue fixed. 9 months later up to today (sound is coming back but at much slower pace; once or twice a day, sometimes once or twice a week) no more warranty to cover this, so i will figure it out later or just live with it. + supercharge whining sound when accelerating 1st, 2nd and sometimes 3rd gear, With AC OFF or ON, not sure if it is coming from alternator, gearbox, turbo or engine, but definitely not a normal noise, but can live with it if it keeps running. + Hard shifting and clunk at Sports+ mode if not revving hard, shifts perfectly on down shifts and higher revs. + 1st, 2nd gear at slow speeds, exiting garage, parking lots etc, is hesitant and is all over. shifting issues maybe resolved if i plan to do transmission maintenance.
Estoril Blue - Coral Red
