07-24-2019, 09:14 AM | #1 |
Rep 197
Ignition Timing Help - Wrongly Gapped Spark Plug?
I installed NGK 2-Step plugs recently. Gapped them to 0.023" give or take. I am noticing a +20% drop off in ignition timing #4 after passing 5.5k rpms or so. What do you think is the cause?
Below are some 3rd Gear BM3 logs. Running e40 + Meth. http://www.bootmod3.net/log?id=5d37bc6ec090c63a4d63fb0b http://www.bootmod3.net/log?id=5d37bc01c090c63a4d63fb06 Should I buy new gapping equipment and double check? My last chisel tool is KO. Thanks |
07-24-2019, 10:36 AM | #2 |
Rep 5,369
It's going to be really hard to get a solid analysis here because you're pushing WAY more power than stock. It could be a gap, a bad plug, knock, poor fuel quality, a failing coil pack(s), a change in ambient conditions, the mood of the DME that day/week, etc. This whole plug gap thing appears to cause more issues than not in late model turbo BMW motors. The fuel and ignition systems are being pushed far harder than they were designed for and even in stock form, they operate within a narrow window. When you add a ton of power, you'll very rarely get a perfectly running car and will be endlessly tracking down oddities like this. The systems operate fine in stock form or slightly modded, but push them a lot harder and they start operating outside of their parameters and things can start getting wonky. It's just the nature of significantly modifying a car. You might think you've solved the problem, such as adjusting the gap slightly smaller, only to have the same issue appear 6 weeks later.
jondagger90.00 |
07-24-2019, 10:51 AM | #3 | |
Rep 197
Its on and off but seems to only happen on ignition #4. Maybe some upgraded coils and checking the gaps isnt a bad idea.... |
07-25-2019, 07:15 AM | #5 |
Rep 197
http://www.bootmod3.net/log?id=5d391b68c090c65e9f4f8eb3
+1 more. The timing has seemed to go away the next day. Seems on - off. The gap for the #4 was 0.025", i adjusted to 0.022. This log includes the spark plug regap but the timing was fine before the gapping too, just wanted to be proactive. |
07-29-2019, 04:17 PM | #6 |
3441
Rep 79,212
Might just be that cylinder is running differently. Swap coils and plugs separately and see if the problem follows. As someone else mentioned methanol flow that isn't port injection isn't going ot be perfect either.
jondagger90.00 |
