11-29-2022, 05:19 PM | #1 |
Rep 5
Rattling/buzzing from under vehicle
Anyone have any idea what this sounds like? Thank you for any input you may have!
https://youtube.com/shorts/cHrhFcIhGzk?feature=share |
11-30-2022, 06:42 AM | #2 |
Rep 399
Check the exhaust flap if you have one, they are known to rattle sometimes or check for a heat shield that might be vibrating on the exhaust somewhere.
charlesstone960.00 |
11-30-2022, 07:02 AM | #3 |
Rep 5
Thank you for your response. I had the flap removed when I had the car straight piped so it's definitely not that… hopefully something heat shield related. It doesn't really sound like wastegate rattle to you right?
11-30-2022, 10:15 AM | #4 |
3621
Rep 3,590
Another one to check is the clip holding the handbrake cables in place above the drive shaft, allowing a cable to touch the driveshaft if the clip breaks.
11-30-2022, 12:12 PM | #5 | |
Rep 5
This may be a silly question… but does the drive shaft spin while the car is in park? Because the noise is still present while stationary. |
11-30-2022, 12:34 PM | #7 |
3621
Rep 3,590
The driveshaft doesn’t spin, but the handbrake cable sheathing can still vibrate against it or other components in the transmission tunnel.
11-30-2022, 12:42 PM | #8 | ||
Rep 3,496
I copied the link off this forum, but I don't have any experience with the clip.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
charlesstone960.00 aerobod3621.00 |
11-30-2022, 01:10 PM | #9 |
Rep 399
I’ve not heard or had wastegate rattle noises, so can’t help you there…Sorry!
12-01-2022, 01:12 PM | #10 |
Rep 5
Thank you all for your input. I believe I have isolated the issue to the rear passenger side exhaust tip as the noise stops whenever I place my finger on it. I'll have a definitive answer by tonight, but I'm almost positive this is what is causing the issue.
