03-02-2019, 05:01 PM | #1 |
Rep 142
Help: Charge pipe install issue
I got the charge pipe into the intercooler but the other pipe (rubbery one) is being a real pain in the ass. I am 2mm away from finishing the install and just can't seem to get it in. Is there a special way to do it or do I need to find someone stronger to help me lol... Been at it for 3hrs
03-03-2019, 08:20 AM | #4 |
Rep 79
Not sure what you mean by the other rubbery pipe. Do you mean the silicon connector between the two charge pipe halves?
If so, I had the same issue initially when installing the VSRF charge pipe. Finally got it to (mostly) line up by rotating the lower and upper charge pipe sections while the coupler was still loose. Btw, does CTS Turbo have different charge pipes for xDrive vs RWD? Last edited by abdiel; 03-03-2019 at 08:26 AM.. |
03-03-2019, 12:40 PM | #5 | |
Rep 142
03-03-2019, 01:17 PM | #6 |
Rep 351
I think he means the turbo to intercooler pipe. it's a flexible pipe.
In the mean time...if you didn't replace the fmic it the tic pipe, it's gotta fit just keep wrastleing with it ! |
03-03-2019, 03:33 PM | #7 |
Rep 5,369
Dish soap is a great lubricant for hoses and then when it drys, becomes slightly sticky to help keep the hose in place.
