2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics what is triangular piece called that covers access to the door side mirrors.
      08-23-2018, 08:02 PM   #1
Rassclaht
Drives: 2015 228i xdrive convertible
Hello,
Looking for the part number for the HK version of the triangular piece covers access to the door side mirrors. I have the base audio system and want to upgrade speakers to include tweeters. The easiest way IMO is to obtain that triangular piece which on on HK equipped cars houses the tweeter.
Unfortunately I have no idea what its called and so cannot find a part number.
I would be fine with a used pair.....
Many thanks.
Dean.
PS the basic stereo is total crap. Shocking for a car of such otherwise good quality.
      08-23-2018, 08:16 PM   #2
Funwithdesign
Arsevader
Funwithdesign's Avatar
https://www.realoem.com/bmw/enUS/sho...diagId=51_8733
Item #10 is what you want. For HK systems the part numbers are:
51337269361
51337269362
peediR1.50
      01-31-2019, 04:10 PM   #3
sethwas
Drives: 228i
without using the HK OEM sail panels, will a 1.5" or 2" tweeter fit?
The OEM one is 1" when mounted in the dedicated sail panel - but if you were to cut a hole does 2" fit with what sits behind the plastic?
Seth
      02-02-2019, 04:54 PM   #4
MarcoZandrini
Drives: 2018 M240i
You’ll have to fabricate something to hold the tweeter. I don’t think there’s any room outward from the back of sail panel or HK tweeter sail panel.
      02-02-2019, 05:46 PM   #5
sethwas
Drives: 228i
thanks - I was under the impression it was sort of hollow inside.
Seth
