04-16-2017, 08:41 PM | #2 |
Rep 1,931
i remember reading they have different bolt patterns, or bolt in a different place. Wont work.
www.nybmwcca.org
04-18-2017, 09:22 AM | #3 |
Rep 2,214
I believe the calipers are the same but the rotor hat/hub has a different offset, IIRC. Was looking into this before as well. Ended up deciding the route to go with would be a 370mm F30 setup w/ m performance rotors. The M2/3/4 rotors are triple the price of OEM m235 rotors, double the price of M Performance rotors, and IMO not worth it unless it came that way from the factory.
What I'd really like to see is some proper 2 piece replacement rotors, to be used with factory calipers. One can dream.. |
04-18-2017, 03:51 PM | #5 |
Rep 41
No, sounds like you need to upgrade to the F8x standard or F30 msport calipers, which I believe are stamped 370. If the M2 brakes are the same as the M235i M Performance BBK, you can reference this thread http://www.2addicts.com/forums/showthread.php?t=1226936
04-18-2017, 05:57 PM | #6 |
Rep 1,541
Unless the 370mm rotors are actually lighter then I would not swap them using the stock caliper.
04-18-2017, 06:11 PM | #7 |
Rep 1,931
Upgrade you lines to stainless steel, brake pads to yellow stuffs, and fluid to motul 600 and youll be good to go.
www.nybmwcca.org
04-19-2017, 12:09 PM | #8 |
Rep 73
04-19-2017, 03:15 PM | #9 |
Rep 1,931
I can only comment on what I've used.
Do you want better stopping power or clean wheels? Yellowstuffs are fantastic for street use. I wash my car every week, so I live with the dust.
www.nybmwcca.org
04-19-2017, 05:14 PM | #10 | |
Rep 5,262
Yellowstuff are basically same as stock dust wise or maybe a little bit worse but I don't buy pads for the looks either.... |
bryan_G011164.50 |
04-20-2017, 12:12 PM | #11 |
Rep 4,509
Current '22 X3M LCI.. |
04-20-2017, 08:52 PM | #12 | |
Rep 5,262
04-21-2017, 10:06 AM | #14 |
Rep 1,541
Awesome, nice to see someone change up the game.
02-20-2019, 09:00 AM | #15 |
Rep 44
02-20-2019, 08:55 PM | #16 |
Rep 1,931
rotors are widely available...
Stoptech, zimmerman, even bmw oem makes slotted and drilled.
www.nybmwcca.org
