11-04-2019, 09:15 PM | #1 |
Rep 68
One Tire 10F Warmer than Others - cause?
I am able to see the tire temperature on my tire pressure gauge and it says that all tires are around 70F except one that is at 82F.
Could it be an alignment issue? That's my first guess. Car only has 30k miles on it. |
11-05-2019, 08:27 AM | #2 |
Rep 913
Set a good baseline - wait till all tires are cooled off and establish the cold pressure - observe from there.
11-05-2019, 09:55 AM | #3 |
Rep 3,494
Brakes come to mind, too.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9˝ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
11-05-2019, 10:09 AM | #4 |
Rep 237
The tire temps and pressures only update every so often. Also, if you take a corner, the outside front tire will have generated more heat than the others.
11-05-2019, 11:17 AM | #5 |
Rep 68
11-05-2019, 11:18 AM | #6 |
Rep 68
I should note that I do get some tire vibrations at highway speed. And this is with new tires
11-05-2019, 11:23 AM | #7 |
Rep 5,577
11-05-2019, 11:25 AM | #8 | |
Rep 68
11-05-2019, 11:30 AM | #9 | |
Rep 68
11-05-2019, 02:56 PM | #10 |
Rep 5,577
Be sure to do a tire pressure reset in the iDrive controller while driving. If you can switch the hot wheel to the other side and see if the high reading switches or stays on the same axle. For the noise make sure the sunroof is closed completely and make sure all the underbody cladding is bolted snug. Last edited by overcoil; 11-05-2019 at 03:46 PM.. |
Uwrwilke21.50 |
11-05-2019, 08:42 PM | #11 | |
Rep 68
As an aside, I've heard that sometimes the BMW radiator can get hotter on the driver side, affecting the front driver side tire. 🤷🏻*♂️ |
11-06-2019, 06:52 AM | #12 |
E4 Mafia
323
Rep 412
Drives: E30, E36/5, E46, F22, F30
Garage List 1990 BMW 325i [0.00]
1998 BMW 318ti [0.00] 2003 BMW 325i [0.00] 2015 BMW 335i [0.00] 2015 BMW M235i [0.00] |
I have the same thing in my 2. while it was in for warranty work I asked the dealer to look into it. they found nothing and cited the brakes. i don't put a lot of faith in that since it happens only on one side, I'm not making that much heat in the brakes with normal driving and it doesn't happen in the similarly equipped f30.
I always suspected alignment and just waiting until I need actually need one. I'm interested in your results after yours! on another note, the TPMS really gets my OCD! when the temps or pressures vary side to side I just want to get out and fix it, no matter how minor! it's funny because in older cars I'd never know unless the difference was huge!
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k)| '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
Uwrwilke21.50 |
11-06-2019, 07:21 AM | #13 |
Rep 3,494
If you want to take it up a notch from there, buy a quality tire pressure gauge and compare what it shows you to what the TPMS shows you.
11-06-2019, 08:06 AM | #14 |
E4 Mafia
323
Rep 412
yeah, I got one, that's how I "fix" it!
11-13-2019, 08:14 PM | #15 | |
Rep 68
Got an alignment and a rotation from dealership, but still have a hot front driver side tire that is 10F hotter and 3 PSI higher when warmed up, than the other tires. Still hear a slight wobble noise at freeway speeds. I jacked up the car and spun the front wheels by hand, but don't notice any real difference in resistance. Also did the wheel shake to see if it's a bearing issue - but solid. So rules those out. Summary: Not tire specific Not bearing Not stuck brakes, from what I could tell Not alignment Not low PSI THOUGHTS? |
celsdogg323.00 |
11-15-2019, 10:25 AM | #16 |
Rep 2
My m235ix dose the same thing and from what I have found it looks to be a common thing across some of the newer cars and isn't something to be too worried about. There is a thread on the f80 bimmerpost forum that talks about this and they ended up using a thermal camera to find the cause, for the f80 at least, to be from an oil cooler right in front of the driver's front wheel. I'd assume that the 2-series is set up about the same way and that is the cause for us as well.
Here's a link to the f80 forum post and another thread on here of people talking about this.. https://www.2addicts.com/forums/show....php?t=1339559 https://f80.bimmerpost.com/forums/sh....php?t=1278907 |
11-16-2019, 01:53 PM | #17 | |
Rep 8
Put your hand on the front right wing when you’ve gone for a good blast and you’ll see why the front right tyre gets warmer! |
