10-18-2019, 09:54 PM | #1 |
Rep 5
Fuse type confusing
The low battery warning make me crazy. So I install a dash cam battery pack which draw max of 20A. When I open the fuse box I am confused.
What is the difference between the two size of fuse in the fuse box? Is there a meaning? How can I identify which one is B+ or ACC? Current I plug a fuse cable to an empty mini slot which Is an ACC. Is it safe? Thanks |
10-21-2019, 12:33 PM | #2 |
Rep 1,352
Here's what I did with mine (also a battery pack install, a Cellink-B).
https://www.2addicts.com/forums/show...4&postcount=11 I used a fuse tap with it's own 20A fuse. I wouldn't do it the way you have pictured as your Dashcam battery is unfused. |
