07-26-2017, 04:10 PM | #573 | |
Rep 16
Yeah, not harming the new baby is a priority. Maiden voyage tomorrow with the puppy in the backseat. She's not a scratcher or a drooler (though I am!). Still going to be hard to keep my eyes on the road! |
07-26-2017, 04:19 PM | #574 |
Rep 8,942
How big? I highly recommend the lookout seat fits nicely in the back of a 2er. My dog immediately passes out unconscious as soon as he gets buckled into his.
07-26-2017, 07:55 PM | #575 |
Rep 16
Australian Shepherd, 9 months, probably 40 lbs on her way to 50. I think she may be big for a Lookout seat. I do put her in a harness, which I attach to the seat belt. She is pretty quiet back there (and trip is pretty short; maybe 15 minutes).
07-26-2017, 08:50 PM | #576 | |
Rep 8,942
Sorry for going off topic folks but dog safety in cars is a cause I fully support. My puppy survived a head on collision with a drunk cab driver blowing stop signs in lower manhattan without a scratch on him due to proper safety gear. My Touareg had $30k in damage and a bent frame.
Viffermike1753.00 |
07-27-2017, 10:47 AM | #577 |
Rep 131
Other upgrade options?
First post, and first BMW, so don't start flaming right away, okay? Just bought a used / demo 2016 M2351 coupe with 1300 miles and a CPO Elite warranty last week, and want to upgrade the audio. It's got Nav, and the Hi Fi audio (?) with 7 speakers. 1- center, 2 in the door, 2 in the rear and 2 under the seats. I've read every post on this thread, and researched Bavsound and other replacement brands and vendors as well, so I have an idea of what those options and suggestions are. I think the first thing I want to do is disconnect the center speaker, get the harness to eliminate the ASD, and replace the speakers. In regard to replacing the speakers has anyone tried to use speakers from another BMW model that had a higher end audio system in it? I see a lot of BMW speakers on Ebay from 7 series that at least look a lot like higher quality aftermarket speakers. The cones appear to be fiberglass / Kevlar / etc., and the magnets are a lot larger. Appearance wise, they look to be a lot better quality that what's standard in the M235i, and even better than the HK speakers in that car. The same with the tweeters, they look to be better quality. Size (diameter) and mounting look to be the same as well. The downside would be that they are used, you don't know how badly they may have been abused, etc. Just a thought, but any experience doing this, or opinions?
Next step will be an amp, and a question on the Technicpnp 7 channel amp harness. I assume it will work with any amp, is that correct? |
07-27-2017, 10:56 AM | #578 |
Rep 465
I'd recommend against using the other BMW speakers.
First, you may end up buying blown or otherwise compromised speakers. Second, small differences in dimension matter: the mounting holes might not line up, the speaker frame might not line up to create a proper seal, the speaker depth might be off, etc. Since the speakers recommended in the thread are (a) known to fit, (b) they have the proper impedance, (c) they're not expensive, and (d) they sound good, I can't really see why one would opt for other BMW speakers, especially since you haven't actually heard them in operation. I'd stick with what works. Congratulations on your new car and welcome to the forum. Last edited by selmeralto; 07-27-2017 at 11:02 AM.. |
07-27-2017, 11:13 AM | #579 |
Rep 8,942
Just using Bavsound site since it's easy to navigate, check things like under seat woofers. You'll see they offer 2ohm, 4ohm, etc. etc. so there's no consistency across different models of car. Yes you can probably score a sweet set of BMW speakers super cheap on eBay, but cheap can become expensive very quickly if you start frying your electronics.
07-27-2017, 01:21 PM | #580 |
Rep 1,345
Initial comments. Focal coax pc100 speakers are super high quality. Got them very discounted from extreme audio in Germany. Great service too.
Super high quality means no break off tabs. The baskets are metal and cutting them off is not for the faint of heart! Also, directable tweeters are excellent, but barely fit under the rear shelf covers. Will likely need to cut off the tweeter covers for more clearance. I'll post pics at some point. Will move to the subs and doors next. |
07-27-2017, 04:52 PM | #581 | |
Rep 2,942
- With OEM speakers, you often don't have any idea about the speakers' specs: ohm rating, power handling, effective frequency range, efficiency, etc. That makes it very hard to implement them on another system, especially if you're mixing OEM drivers from at least two different models. - OEM speakers from cars like the 7 Series are frequently designed to work at odd ohm ratings, which is a common tactic of system designers to keep SPL under control at louder volumes when those drivers are inherently underpowered with programming from a fiber-optic MOST network. This is precisely why cars like Volvos almost never have upgraded stereos; speakers that will work with the existing system simply do not exist because the speakers in, say, the XC90 operate at three different ohm ratings. To get them to work properly means $1,500-$2,000 in MOST interfaces, DSPs and amps just to start. - Higher-quality OEM speakers frequently have a very specific sonic task within the system they're designed for, and are thus generally (but not always) poor choices to handle wider sonic duty. A great example of this are the ribbon emission tweeters that Burmester systems use in recent-model Porsches. Ribbons are phenomenal for treble, but they're fragile and are typically not the best choice for frequencies under 4k. Unless you've got midrange drivers dedicated to the 750-5k range, ribbons don't work well in a mobile environment.
07-28-2017, 06:32 AM | #582 |
Rep 131
Thanks for all the replies on my question. I had thought about and considered most of the "cons" mentioned regarding speakers from other BMW models. That's why I was wondering if anyone had done it, and what the results were.
07-28-2017, 03:29 PM | #583 |
Rep 16
Moving along, but still running into stuff...
ASD bypass successfully installed. Now trying to pull the stock rear speakers, with JL replacements ready. How do I get the blue clips out of those rears? Is it just a hard pull? Or is there a tab that I need to depress, but don't see? Thanks. |
07-28-2017, 04:12 PM | #584 | |
Rep 8,942
07-28-2017, 04:22 PM | #585 | |
Rep 16
There are two separate clips on the speaker (+ and -), but the pigtail has a single "female" connector for the speaker clip(s). And two wires...a red and a black. I appreciate all the help...and no "you have to be kidding me's"! |
07-28-2017, 04:37 PM | #586 | ||
Rep 8,942
07-28-2017, 05:20 PM | #588 | |
Rep 8,942
Not sure if your new stuff has separate tweeter or not. Bavsound for example separate mid and tweeter you plug a y cable into car harness then one end into mid and other into tweeter.
07-29-2017, 06:24 AM | #589 | |
Rep 16
Connectors to the existing speaker were super hard to pull out. Thought if I pulled any harder I'd yank the wire out of the connector. Will try again this morning. Again, thank you. |
07-29-2017, 09:01 AM | #591 | ||
Rep 8,942
Re other poster I actually found more prone to breaking clips w screw driver. A good yank is all you need. I've done what 20 speakers in multiple cars that way no issue.
07-30-2017, 06:41 AM | #592 | |
Rep 16
Appreciate all the help. Audio closer to being on par with the car...which is incredible. Perfect follow on to my '03 330ci. |
07-30-2017, 05:10 PM | #593 |
Rep 1,345
Worth noting on this thread that the Focal IFBMW-S Integration set with 100 mm woofers and separate tweeters DO NOT fit the F87, M2. Incorrect hole spacing.
HOWEVER, it appears that housing of the speakers can easily be drilled to accommodate the holes needed for the M2. I will likely try this as returning to Germany would probably be expensive and I enjoy the sound of the Focals. More to come. Last edited by ryem3; 08-01-2017 at 09:48 PM.. Reason: Correction of guidance |
07-31-2017, 01:43 PM | #594 | |
Rep 1,345
