2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions MPBBK - coding required post DIY install ?
      08-19-2014, 01:01 PM   #1
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Gents
Can't reconcile cost of MPBBK for f2x series supply and fit by dealers here in the UK. Considering a cheaper DIY alternate as follows:-
- use blue msport calipers off an f30 335i and 370mm dia MPE rotors for the front and MPE 345mm rotors on rear so I retain matching blue calipers front and rear.
Does the car need coding for MPBBK ie abs re-calibration ?
If so can this be coded retrospectively ?
Advice welcome, thanks in advance,
BP
Current '22 X3M LCI..
      08-19-2014, 01:11 PM   #2
Cybertronic
Drives: G30 M550i, E30 M3
Dont know if thers actually anything electronically different, but if it were me, I'd add the "2NH - M Sport Brakes" to the VO/FA just to be sure.
      08-19-2014, 01:29 PM   #3
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
i think it changes the brake balance between front and rear
you could use the NCD/CAFD tool and the FA-CAFD section and see what changes are made
      08-19-2014, 04:14 PM   #4
pikcachu
pikcachu's Avatar
1403
found it this is what changes in the DSC ecu
DSC_CT01 > DSC_CODIERDATEN_LIEFERANT_CONTI 3004 > C_Trockenbremsen_Druckhoehe_C = Reduzierung um 0.2 bar
      08-20-2014, 02:30 AM   #5
Bee Pee
Bee Pee's Avatar
United Kingdom
1779
Drives: AW M2 DCT
Pikcachu,
Thanks.
Did a search for SBPR in F30 forum and came up with these 2 threads
http://f30.bimmerpost.com/forums/sho...highlight=SPBR
Unclear whether or not these are relevant/useful for F2x series ??
BP
