11-08-2018, 07:27 AM | #1 |
Rep 13
Quick Question on M240i Wheels
Hi all, I have a RWD M240i with staggered Michelin PSS today.
I'm looking to put on a set of Michelin PA4 winters, 225/40/R18. I was wondering if these rims will be ok, the offset numbers had me a little worried as they appear less than the stock. https://www.1010tires.com/Wheels/CLO...inted/Gunmetal 18x8 5/120 bolt 35mm offset 72.6 hub bore Will this work or look strange in any way? As a backup plan it looks like these *should* fit the standard rims, even though it's staggered based on some posts I've seen on this forum. (my understanding is my rear rims are probably a little wider, not just the tires) I might switch to using those rims for summer at some point if they're working out ok. Thanks! |
11-08-2018, 10:01 AM | #2 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
They’ll fit, maybe with a sliver of poke. 8in wide wheels fit better with 40-43mm offset though
oldschoolswish3.00 |
11-08-2018, 12:05 PM | #3 | |
Rep 823
11-08-2018, 01:11 PM | #5 |
Rep 823
Here's pics of my set up mentioned to give you an idea.
11-10-2018, 10:59 PM | #7 |
Rep 823
