01-22-2016, 08:44 AM | #1 |
Rep 204
Weight of stock M235i wheels?
Hi. I did a couple of searches, but could not find the answer on here. Does anyone know the weight of our stock wheels?
01-22-2016, 10:53 AM | #2 |
Rep 1,931
436M style front 25.2 lbs rear 25.4 lbs.
Found this: http://www.2addicts.com/forums/showthread.php?t=1167311
www.nybmwcca.org
01-22-2016, 08:54 PM | #3 |
Rep 5,262
01-22-2016, 10:12 PM | #4 | |
Rep 204
Seems like the winter wheels I'm considering are 10 pounds per wheel lighter. That's going to make a pretty big difference in unsprung weight, but then again, I don't know the weight of my winter tires. |
01-22-2016, 10:13 PM | #5 |
Rep 204
11-24-2018, 09:55 AM | #7 | |
Rep 970
I've turned into a bit of a weight weenie since discovering how much more performance and handling you gain by lowering unsprung rotating weight. Dyno results show real gains in WHP and TQ. My wheels are these: https://www.realoem.com/bmw/enUS/par...&q=36117852489 weigh in at 11.585 KG or 25.54 lbs I am going to be replacing the stock (square) set up w/ OZ Ultraleggera in silver @ 18.6 lbs Dumping the Stock Pirelli Cinturato P7 All seasons or a set of General Max AS-05 @ 20 lbs each Net weight saving over stock will be 35.6 lbs Dyno comparisons where that much unsprung weight is shed show gains of at least 8 WHP and 9 WTQ or a bit better if you don't add wider tires. https://mbworld.org/forums/c63-amg-w...orsepower.html |
11-24-2018, 11:55 AM | #8 | |
Rep 558
Compared to other UHP AS I have tried (Conti & Michelin), they felt "squirrely" on turn-in, "squishy"/"uncertain" in the turn and they were the noisiest, by far. I was happy to get them off the car and would not buy them again.
11-24-2018, 12:47 PM | #9 |
Rep 970
Interesting.................
I was on the Tire Rack website and saw their review on The General Max. Got really good marks overall. These tires are new as of May 2017...not the old G Max https://www.tirerack.com/tires/tests...y.jsp?ttid=238 Video https://www.tirerack.com/tires/tests...y.jsp?ttid=238 My understanding the Generals use the Conti technology in their build so the tires compare favorably. I have some Conti Extremem Sport DW's on my Mini and they perform great. |
11-24-2018, 04:45 PM | #10 |
Rep 3,493
Interesting. Mine came in F - 48#, R - 51# when weighed on a doctor's balance beam scale. That was after 2K of use on the tires.
11-24-2018, 05:36 PM | #11 |
3612
Rep 3,578
For a summer tyre with a 0.2m tread width and 2.0m circumference (225/40-18 meets that criteria) , assuming about one-third void volume, then each mm of tread wear weighs about 0.3kg, or about 2kg for tread wear from min to max.
11-25-2018, 07:32 AM | #12 | |
Rep 558
