2Addicts | BMW 2-Series forum Classifieds Members Classifieds Engine / Drivetrain / Exhaust / Bolt-ons *SOLD* - USED - Complete Rear Subframe/Differential/Axles/Suspension EDC Dampers
      07-13-2023, 11:43 PM   #1
JCDakarM3
JCDakarM3's Avatar
Drives: F80 M3 - E90 335i - E83 X3
Rear Subframe from a 2017 BMW M240iX with 3,083 Miles on all components. Compatible with all F Chassis 2/3/4 Series vehicles, both RWD and xDrive.
2.81 Rear Differential Ratio.
I am willing to sell this complete, or the following usable components can be sold individually:
(x1) 33316792505 - Rear Axle Carrier (Subframe)
(x1) 33108485723 - Rear Axle Drive (2.81)
(x1) 33208680350 - Rear Output Shaft Right
(x1) 33208680351 - Rear Output Shaft Left
(x1) 33326792515 - Rear Wheel Carrier Left
(x1) 33326792516 - Rear Wheel Carrier Right
(x2) 33326867540 - Camber Arm
(x2) 33326792533 - Track Strut Arm
(x1) 33326792543 - Control Arm Left
(x1) 33326792544 - Control Arm Right
(x1) 33326792539 - Guiding Link Left
(x1) 33326792540 - Guiding Link Right
(x2) 34526869322 - Wheel Speed Sensor
(x4) 34526791926 - Wire Clip
(x2) 34526791949 - ABS/BVA Bracket
(x2) 37146870000 - Level Sensor
(x1) 37146797816 - Left Ride Height Sensor Bracket
(x1) 37146783046 - Right Ride Height Sensor Bracket
(x1) 37146797817 - Control Rod Right
(x1) 37146867535 - Control Rod Left
(x2) 33416867261 - Drive Flange Hub
(x2) 33416792356 - Wheel Bearing
(x1) 33556853475 - Rear Stabilizer Bar
(x1) 33506785607 - Left Stabilizer Endlink
(x1) 33506785608 - Right Stabilizer Endlink
(x2) 37126865547 - Rear Shock Absorber
(x2) 33536850537 - Rear Shock Absorber Boot/Bump Stop
(x2) 33506864452 - Rear Shock Absorber Guide Support (Top Mount)
(x2) Unknown P/N - Rear Coil Spring
(x1) 34216792243 - Left Protection Plate
(x1) 34216792244 - Right Protection Plate
(x2) 34206797605 - Rear Rotor, Non Ventilated, 345x24mm
(x2) 34406857639 - Handbrake Cable
- Both Rear Calipers/Rotors/Dust Shields SOLD
All Hardware/Bushings associated with the rear subframe, not listed above, are also included. If you are looking for a component not visible in the pictures, please message me to verify that it is included.
NOTE: Although included, both trailing arms, P/N: 33326792525 are damaged.
If you need proof of milage or have any questions, feel free to message me and I can provide the donor vehicle's info.
Item is listed on EBay, and can be purchased there if you prefer the added buyer protection. I do, however, have the item listed for more on EBay to cover the seller's fees.
EBay Listing - https://www.ebay.com/itm/175816483877
I have other B58 and F22/F80/F82/F87 items listed on the forum and Ebay that may be of interest, so be sure to check out my EBay "For Sale" page.
I prefer local transactions (Cash in hand, or PayPal - NO CHECKS), but I am willing to ship at buyer's expense.
Item is located in Upstate NY, zip code 12533
Feel free to message me with any questions.
Thank you for your interest!
      09-17-2023, 07:39 PM   #2
JCDakarM3
JCDakarM3's Avatar
Bump! Still Available 9/17/23. Both Rear Calipers/Rotors/Dust Shields SOLD
      09-27-2023, 05:29 PM   #3
JCDakarM3
JCDakarM3's Avatar
Bump!
