07-10-2017, 08:22 PM | #1 |
Rep 328
Drives: Ex BMW owner, will return soon
How to remove lower trunk trim to install dynamat
As title states, I ordered dynamat to fill the trunk with it. I would like to know where can I find a step by step guide on how to safely remove everything to get to the bare metal of the car. Considering the battery is in the back, I'm assuming it's a bit more complicated than other cars.
07-10-2017, 08:59 PM | #2 |
Rep 986
It's a lot of plastic pop rivets.. Get some plastic automotive trim tools, and a set of torx bits (their are two on top of the trunk mat if i remember correctly).
That should get you 90% of the way there, and just start pulling. I did some 80mil mat in my trunk, but i did not rip out the battery and such. I put it on any accessible open metal surfaces, and i took out both of the side trunk liners to get some more metal there. |
SliChillax486.00 |
01-15-2018, 02:25 AM | #4 |
Rep 328
bluesman826646.00 |
01-29-2018, 04:46 PM | #6 |
Rep 220
i now this is the the end to end guide but will get you started with removing the stuff in the trunk..
http://www.2addicts.com/forums/showt...ck+amp+install |
