09-15-2016, 10:39 PM | #1 |
Rep 103
Eibach sway bars for 228 and upgrade advice
I've got a M Sport 228, downpipe and JB4 pretty much only mods so far. Eibach sways are a lot cheaper than the H&R, i can't remember if front or rear requires the extreme amount of labor but i'll probably be doing some other stuff at the same time.
http://performance-suspension-eibach...ay-bar-only-84 Thoughts on Bilstein B14, M4 LCA's, and eibach rear sway bar? Also thought about doing either Bilstein or Koni shocks with Eibach springs and the rear sway. What worries me is the springs lower the car more up front and the LCA's would be even more drop and i don't want a bunch of rake. Coilovers fix that but at the expense of ride quality in my previous experience. M Performance suspension is also an option, i really don't want to run coilovers but seems like you need to be able to adjust ride height to compensate for the M4 LCA's. Am i overthinking this? PS don't want aftermarket camber plates unless somebody has some that aren't noisy and ride smooth. |
09-16-2016, 04:06 AM | #2 |
Rep 4,522
Fit M4 TS with LCAs - reduces lowering impact of LCAs alone.
Current '22 X3M LCI.. |
09-16-2016, 11:38 AM | #3 | |
Rep 2,942
Unless you've got damn near a commercial-grade garage and/or some very good mechanic skills, I would not try installing sways on a 2 Series as a DIY.
09-16-2016, 01:51 PM | #4 |
Rep 845
I did the aforementioned sway-bar installation with a professional. The labor is 4 figures.
Save your money and get a differential before you think about getting expensive coils or sway bars.
09-16-2016, 08:40 PM | #5 | |
Rep 103
I would love a limited slip rear, what are the options for a 228 with an automatic though? I do plan on trading for a M2 in 2 years so i don't want to put too much money in to it either. I may just do the M Performance suspension, M4 LCA's and tension struts. That seems like it would keep a nice ride quality and still be a great handling upgrade. |
09-17-2016, 02:41 AM | #6 | |
Rep 4,522
If yr car doesn't have the m235i chassis brace - I'd fit that too to help tie rear subframe to the body.
09-17-2016, 06:38 AM | #7 |
Rep 566
09-19-2016, 02:34 PM | #8 | |
Rep 2,942
Tpeterson156.50 |
03-14-2017, 12:47 AM | #9 | ||
Rep 103
