2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Wheel spacer testing - 5mm, 10mm, 12mm, 15mm
      07-28-2014, 10:53 AM   #23
pikcachu
pikcachu's Avatar
1406
Drives: M235i (F22 Red angel)
So far I found they need to be 5x120 bolt pattern / 72.5mm center bore
and 14 x 1.25mm bolts
      07-28-2014, 12:12 PM   #24
HX_Guy
Drives: 2014 BMW M235i
72.6mm center bore according to H&R. The Ubercentric ones from Amazon are also 72.6mm.
The stock lug bolts are 27mm shank length, so the new bolts have to be 27mm + whatever the spacer thickness is. It doesn't have to be exact because there is quite a bit of clearance before the bolt bottoms out so if you do a 12mm and 15mm spacers, you could use a 40mm shank bolt no problem.
2014 BMW M235i 6MT
2012 Mercedes E350 Bluetec
      07-28-2014, 12:21 PM   #25
pikcachu
pikcachu's Avatar
1406
maybe 12mm all around?
      07-28-2014, 12:28 PM   #26
HX_Guy
Yeah that would work too...really there's no right or wrong answer here I don't think, just personal preference.
2014 BMW M235i 6MT
      07-28-2014, 01:33 PM   #27
pikcachu
pikcachu's Avatar
1406
the 18mm doesn't look too bad here either...
      07-28-2014, 01:34 PM   #28
HX_Guy
To me it does, makes the back end looks weird in proportion to the front. I like this weird balance of almost looking OEM but also aggressive, like you can't really tell if it came like that from the factory or if it was modified.
2014 BMW M235i 6MT
      07-28-2014, 01:39 PM   #29
pikcachu
pikcachu's Avatar
1406
i guess i would have to see it in person... i'm between 15R-12F or 12 all around....
      07-28-2014, 06:35 PM   #30
VMRWheels
General
VMRWheels's Avatar
2048
Drives: BMW
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Great thread! Thanks for sharing
      07-28-2014, 09:59 PM   #31
oscr972
Drives: M235i 4/16/14 ED AW/Terra
Thanks for all the work HX_Guy. I'm running 12/15 and will swap to 15/12 based on your research. I agree that 15 is a bit too wide in the rear.
      07-28-2014, 10:57 PM   #32
pikcachu
pikcachu's Avatar
1406
damn.... i was going to order 12F - 15R.... you guys are killing me...
maybe back to 12 all around...
I don't get it this looks pretty good to me
      07-29-2014, 02:04 AM   #33
HX_Guy
It's the angle, honestly that does not look like an 18mm spacer in the rear.
18mm is going to look weird...I think 15mm looks weird and we've had two other member say the same thing. Go with 12 if you want it to look aggressive, you'll like it.
2014 BMW M235i 6MT
      07-29-2014, 06:39 PM   #34
pikcachu
pikcachu's Avatar
1406
was able to play around with a 14mm Styrofoam flat sheet and kind of see what you mean on the back....it's like the rear is already sticking out a bit...
So I think 12mm should be ok on the back....
Now I wonder if I should put 15 or 12 on the front
What did you end up with?
      07-29-2014, 06:41 PM   #35
HX_Guy
Still have the 15mm front and 12mm back right now but I just got the 10mm in the mail today and will put them on one side tomorrow to do 12mm front and 10mm rear for a few days and see which I like more.
2014 BMW M235i 6MT
      07-29-2014, 06:48 PM   #36
pikcachu
pikcachu's Avatar
1406
put them today so I can decide and send my order tonight
      07-29-2014, 07:03 PM   #37
HX_Guy
Haha, you already saw what the 12mm front and 10mm back look like in the pictures. I'm going to run them for a few days and see how I feel about it.
2014 BMW M235i 6MT
      07-29-2014, 07:21 PM   #38
pikcachu
pikcachu's Avatar
1406
ah you are right... just looked at it.... I think I'm going 12mm all around... I like the 12F front and 10R is ok but I think I would like 12R better
wish me luck
      07-29-2014, 07:23 PM   #39
HX_Guy
You could always order just one set of 12mm and put one of the spacers on the front and one on the back on just one side of the car and see how you like it.
2014 BMW M235i 6MT
      07-29-2014, 07:28 PM   #40
pikcachu
pikcachu's Avatar
1406
would you drive with spacers only on one side ?
ya thing is that I don't want to pay twice for shipping
      07-29-2014, 07:29 PM   #41
HX_Guy
Haha I didn't mean drive around, I meant to visually see how it looks. I'm sure if you took a spin around the block it wouldn't harm anything but I wouldn't leave it like that long term I don't think.
2014 BMW M235i 6MT
      07-29-2014, 07:30 PM   #42
pikcachu
pikcachu's Avatar
1406
      08-02-2014, 12:42 PM   #43
HX_Guy
Took all the spacers off earlier this morning to send them back, between improper fit and some vibration issues, I've decided I'm going to go with a trusted brand like H&R over these Ubercentric.
I decided against the 15mm front and 12mm rear...will do 12mm front and 10mm rear, but I am thinking maybe 13mm front would be a good compromise. Definitely 10mm rear though.
BTW the car looks terrible now without any spacers...just looks so weak, I don't know, looks so off. Spacers are definitely a must, or aftermarket wheels that are either wider and/or better offset than stock.
2014 BMW M235i 6MT
      08-02-2014, 01:41 PM   #44
zkeeper
zkeeper's Avatar
Drives: 2017 M2 & 08 Z4 si
Let us know please, if the H&R really slip on...slip off without fouling the dust cap or having to "force it a bit" to make it all work. This spacer issue for mainly curb appeal is not worth it if the machine work on fitment is not right.
Worst case I guess, is someone could take one that is "close" but not right, have a competent machine shop mic it, and turn it to really fit proper.
