10-09-2016, 11:53 AM | #1 |
Rep 17
Subframe bushings?
Can anyone speak to subframe bushing upgrades? I've seen a few posts on this forum where guys have said they've put in more aggresive, even solid, subframe bushings, but I haven't seen anyone really talk about what it did to the car. What I'm wondering is, what difference have you seen in the chassis characteristics? Would you consider it a real performance upgrade or more of a 'because racecar' type thing? Feel free to divulge if you have done this on non-f22 chassis's.
10-10-2016, 03:01 AM | #2 |
Rep 4,528
Duke,
Have a read of this thread. DVC is yr man and BTW your M235i will already have the underbelly chassis brace I refer to in the thread BP
Current '22 X3M LCI.. |
jpnh1424.50 |
10-15-2016, 04:05 PM | #5 |
Rep 1,372
I'm thinking FCA bushings because I hear the stock ones die an early death as a result of enthusiastic driving. Problem is I hear too many models of solid bushing introduce extra vibrations because they're so stiff. Wouldn't it be the same for the sub frame bushings?
01-27-2017, 11:41 AM | #6 | |
Rep 1,252
im going to fit my quaife lsd soon, also need adjustability of front camber due to variance of left and right
Docrace 6266
01-31-2017, 08:03 PM | #7 |
Rep 183
Just did the Delrin subframe bushes from Bimmerworld.
Made a day and night difference. It helps putting power to the ground so much. Gone is the wobble from the subframe moving. especially when you are powering out a bumpy corner. No extra harshness or vibration. 100% recommend it.
2008 BMW M3 | 6MT | OEM Exhaust Mod | Black Grilles | |
02-01-2017, 08:45 AM | #8 | |
Rep 1,252
And thinking of LSD bushes considering that im also doing quaife install soon what do you think
Docrace 6266
02-01-2017, 12:52 PM | #9 |
Rep 957
02-02-2017, 12:28 AM | #10 | |
Rep 4,528
02-02-2017, 02:13 AM | #11 |
Rep 566
Don't think replacing one side at a time is great idea.
02-02-2017, 11:30 AM | #12 |
Rep 957
going to be a huge pita, best to drop.
02-02-2017, 06:49 PM | #13 |
Rep 1,184
02-03-2017, 01:21 AM | #14 | |
Rep 183
My shop charged 6 hrs for the job which I think is more than reasonable. I am pretty sure there is a DIY from forum member VTL. Check out his build page in the Australia 1 series E series forum.
02-03-2017, 03:28 AM | #15 |
Rep 4,528
Neither do I !!!
I was suggesting if the swap could be 1.work on one side 2 then switch to work on the other side You change out all 4 bushes without lowering s/frame completely.....
02-03-2017, 07:28 AM | #16 |
Rep 957
I did myself with a portable lift (trackback). You could do it I guess, you would prob have to cut out most of the bushings and then press out metal, also not sure if you could drop enough to seat new bushings. Really you can disconnect the driveshaft at the transmission and just replace those 6 bolts, drop the whole subframe LSD, suspension and change. III dropped into a moving dolly rolled out, changed rolled back in. 6 hours is more than enough. I see no benefit of trying this on the car. Just a lot of headache.
