2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB Low Coolant and Jammed Expansion Tank Cap
      08-26-2020, 03:47 AM   #1
Lenman
Australia
Drives: F23 M240i Convertible
Hi
New to the 2 series here and having some issues with the coolant.
I have been getting alerts on starting of low coolant levels. Not every day every couple of days.
Now I have popped the hood and managed to open the small expansion tank cap which i now understand to be the turbo cooler circuit.
I was under the impression that this was the only radiator expansion tank. half the reason for that is my inexplicable inability to open the main radiator expansion tank cap. The bigger one. I can unscrew it aybe 1 or 2 revs and then it becomes so tight its impossible to remove.
Ive tried it first thing in the morning when cold.
Is there some trick to opening this cap? Should it just screw off like the other one?
EDIT: I got it open. Is there meant to be a floating dip stick. Hoping not otherwise it must be VERY low!
Cheers
      08-26-2020, 05:34 AM   #2
gosi
Drives: M240
There is a min-max plastic fixed dipstick in there. If you are getting warnings you are probably below minimum. These engines loose coolant inexplicably and it is considered normal. No one that I am aware of has yet to figure out where it goes.
      08-26-2020, 05:43 AM   #3
Lenman
Australia
took about 2-3L to get it to max. The coolant alam has been going off for a while. heres hoping everythings fine.
      08-26-2020, 04:53 PM   #4
iv-128i
bmw
iv-128i's Avatar
Drives: 2017 m240i, prior : 2011 128i
2011 BMW  [0.00]
Welcome to the club of b58 coolant dissapearing mystery lol !
M240i F23
