2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack Wheel help please
      08-19-2020, 02:45 PM   #1
Si-M240i
United Kingdom
137
Drives: M240i LCI
Wheel help please
Wheel question... so I want lightweight wheels for my 2018 Lci M240i for the following sizes give or take 1 or 2mm on the Offset.
Style wise I like the Apex EC-7, so similar to that.
They need to fit with the BMW M Performance brakes too. Anyone know of any?
Front: 18" 8J ET40
Rear: 18" 8.5J ET47
As I only want to go to the following tyre sizes, do not buy ant to use spacers and am not interested in changing suspension or camber, may requirements are quite simple. I also dint want 8.5, 9 or 9.5 J wheels
Tyre sizes I want:
Front: 235 /40
Rear: 255 /35
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
      08-19-2020, 09:12 PM   #2
aftercorbu
aftercorbu's Avatar
Drives: 20 M2C, 20 S3
There are some great vendors on here that can help you get close with these specifics. To get exactly what you want you may need to go custom offsets. There are several brands out there that allow that. I see you are in England. Probably a good idea to check with a solid local shop that is experienced with BMW Fitment. Good luck in your search!
      08-20-2020, 12:31 PM   #3
PeterWT
PeterWT's Avatar
Drives: '17 M240i, AT, BSM
BBS CH-R in 18x8in ET40 & 18x9 ET44
https://bbs-usa.com/road_wheels/whee...s.cfm?wheel=48
Si-M240i136.50
      08-20-2020, 12:48 PM   #4
Si-M240i
United Kingdom
137
Drives: M240i LCI
Good sizes and off set but expensive and would probably have 30% on top for import tax 😞
      08-20-2020, 02:25 PM   #5
PeterWT
PeterWT's Avatar
Price was not one of the criteria you listed.
Si-M240i136.50
      08-20-2020, 02:29 PM   #6
Si-M240i
United Kingdom
137
Drives: M240i LCI
Lol. Just search UK supplies and it's cheaper and no import tax either. Quite tempted to go for it. Quite a lot of poke on the rear wheel. Will they take a 255 tyre without rubbing on oem suspension?
      08-20-2020, 03:27 PM   #7
PeterWT
PeterWT's Avatar
I had a 255/35 on an 18x8.5 ET38 and now I have a 265/35 on an 18x9.5 ET53 w/o issues.
So, a 255/35 on an 18x9 ET44 should be fine. You can add more negative camber in the rear if needed, because it is adjustable, unlike the front.
Si-M240i136.50
      08-20-2020, 03:47 PM   #8
Si-M240i
United Kingdom
137
Drives: M240i LCI
I don't want to dial in more camber. I want to be sure the 255 will fit with OEM set up with a 9j et44
