Turbo Transformer Boost Controller. Simple, Reliable & Fun! |
07-19-2020, 06:20 PM | #1 |
Rep 190,750
I had the chance today to try the Turbo Transformer in my car, and I'm very impressed!
It's a very simple piggyback with only two sensors to connect. It'll take a few minutes to install. One of its best features is Bluetooth capability that allows you to use the TT app to change maps and settings. I took a few screenshots of the app,and I figured i would show you how it works. Setup
Base PSI: This is the PSI level at which the tuner is active. when your boost is below this PSI, the unit is not active and the car is running at stock power Delta PSI: This is the maximum amount of PSI the unit will be adding to stock. Its set to +2 PSI by default but can be increased to +4 PSI (please use with caution) Slope (Rate):
Graph:
Power Modes
Power Default
Max Eco
Hybrid
Custom
07-28-2020, 09:34 AM | #3 |
Rep 190,750
You are correct about the owner of the Turbo Smarter.
08-13-2020, 08:49 AM | #4 |
Rep 190,750
08-20-2020, 01:31 PM | #5 |
Rep 190,750
08-27-2020, 11:19 AM | #6 |
Rep 190,750
09-01-2020, 03:09 PM | #7 | |
Rep 439
Drives: 2016 M235i Xdrive 8A
Is this in place of Bm3 tune Or In addition to Bm3 tune? To add even more boost?
2016 F22 M235 8A HK NBTevo | CTS HEX Intake | CTS Chargepipe | Gplus Intercooler | VRSF DP | BM3 Stage 2+ | 18" CSL Replicas | XHP X-Delete |
09-02-2020, 11:00 AM | #8 | |
Rep 190,750
You can always use it as an additiona to bm3 for more boost
