04-13-2016, 08:42 PM | #1255 |
General
10515
Rep 41,058
Drives: 2018 Alpina B6 650ix GC
Turn car off for an hour and try again.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-13-2016, 09:01 PM | #1256 |
Rep 1,202
Can do.
Is there a way to check to see if it's reading Windows showing an unidentified network? I've googled this issue and the common issues (connection, missing blank dist folders, ignition not being fully on) don't seem to be it. Don't tell me BMW updated the software or something. |
04-13-2016, 09:03 PM | #1257 | |
General
10515
Rep 41,058
04-13-2016, 10:25 PM | #1258 |
Rep 1,202
Well, here I am, roughly an hour later, still no bueno. This is what I'm looking at if it helps
View post on imgur.com |
04-13-2016, 10:27 PM | #1259 | |
General
10515
Rep 41,058
LAN Adapter has Dynamic and not Static IP Address?
04-13-2016, 11:03 PM | #1260 |
Rep 1,202
04-13-2016, 11:06 PM | #1261 |
General
10515
Rep 41,058
Try resetting Winsock Adapter from Command Line.
04-14-2016, 08:54 AM | #1263 |
Rep 6,991
Are you running Windows 10 on your Mac using a virtual machine? That may be part of the issue here. I'm using a 2010-vintage Dell Mini-10 laptop/netbook running Windows 10 and E-Sys 3.27 with launcher. I just coded the wife's 2016 F23 after updating from E-Sys 3.26 and an older version of psdzdata. The Mini-10 has been upgraded to 2GB RAM, but other than that, it runs Windows 10 ok and no problems connecting to either her car or my 2013 F30.
Try checking your Windows 10 Device List for the ethernet adapter and then see if you can get a newer driver for that device. After upgrading to Win10 on my system, I noticed that there was an immediate update for both the graphics and network adapters (wireless and wired). Again, it's dependent on what virtual device is used to link Win10 to your Mac's ethernet hardware. My guess is you'll have success using a "native" Windows laptop rather than your Mac.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 04-14-2016 at 09:00 AM.. |
04-14-2016, 09:06 AM | #1264 |
Rep 1,202
I'll have to check that, thanks. So funny story, the computer I'm using is a 2010-vintage Alienware M11x laptop. I hadn't used it in years so instead of sitting for hours updating it in Windows 7 I just forced the Windows 10 update on it. I bet something's out of date. The other laptop I was going to use, my even older MacBook, has Windows 7--but its copy was even older/more out of date than the M11x. Unlike the M11x though I was just gonna clean install Windows 10 instead of just doing the update like on the M11x. I stopped that process when I remember I still had the M11x. Well either way I'm gonna update some stuffs tonight.
04-21-2016, 12:40 PM | #1265 |
Rep 6,991
Any luck yet? You're probably right about an out-of-date driver. Also, not all older systems are "certified" to run Windows 10. Best way to check is to connect the laptop via ethernet cable to your router (or cable modem), and if you get a connection there, that tells you the wired ethernet adapter is working. Being an Alienware machine, I'd think its ethernet adapter could handle faster speeds/protocols, but it's hard to say. My mini-10 seems to work fine, but it has a more "normal" adapter than your gaming-level system. It's very possible that they didn't update the driver for that specific adapter, which I believe is part of the motherboard and not replaceable like the wireless adapter is.
04-21-2016, 12:54 PM | #1266 | |
Rep 1,202
For the curious, it's Windows 7 because my MacBook is so old Apple doesn't officially support Windows 10 in Bootcamp with it. I tricked it into installing Windows 10 but without driver support nothing really worked as it should. Wish me luck. |
04-22-2016, 08:21 AM | #1268 |
Rep 6,991
Ah...bad luck, indeed. Well...maybe you should look for a used "normal" laptop - something like a Dell Inspiron or an HP Pavilion. If you're running any Windows version via an emulator like Bootcamp on a Mac or VMware on a PC, you may run into issues like the one you're seeing due to the "virtual devices" created by the emulation software and the internal drivers provided for them. My older Dell Mini-10 is great for coding despite its resource limitations because it's small and easy to set up inside or outside the car. I was quite surprised that it works as well as it does, but it's the only laptop in the house with an ethernet port. The other two are "ultrabooks" with wireless only.
04-22-2016, 08:31 AM | #1269 |
Rep 1,753
Dang, that sucks. You're gonna spend more time trying to get coding working than you will actual coding. :/
04-22-2016, 08:37 AM | #1270 |
Rep 1,202
Bootcamp isn't emulation it's an aid to dual boot Windows on a Mac, so there shouldn't be any virtual devices or emulated drivers, well no more than a normal laptop would use. Both laptops can talk fine to my home router, so I wouldn't think it's a laptop issue. Unless BMW locked out this software for the 2016 cars (unlikely, as others here have coded their MY16 vehicles) I'm thinking it's the cable.
Just out of curiosity's sake, what does Windows say when properly connected to the car? Is it still just an unidentified network with the little yellow triangle showing an error? Is there a particular order in which to set up everything (cable, laptop software, car start) I missed? Pretty much. There's gotta be a simple reason this isn't working. |
04-22-2016, 08:59 AM | #1271 | |
Rep 6,991
I forgot that Macs are now using the Intel processors/chipsets like PCs and are capable of booting Windows. There are probably some subtle differences, but I know people who run Mac OS on PC hardware, so it's likely not that big of a deal.
04-22-2016, 10:18 AM | #1272 | |
Rep 5,262
Also are you sure you are plugging in the cable correctly into the OBDII? You need to make sure it's tight and that it doesn't wiggle to the sides else it could mean that some of the pins on the car's connector is bent and doesn't let the pin from the cable to go in... This is what you see when the cable is not connected right |
04-22-2016, 02:51 PM | #1273 |
Rep 6,991
Clearly then, (with apologies to the author of Cool Hand Luke), what we have here...is a failure! To communicate!
04-23-2016, 01:58 PM | #1274 | |
Rep 1,202
That screenshot is exactly what I see. I think I know my error: I've been gently sliding the OBDII connector on and only pushing it until it clicks. This afternoon when I get a chance to give it another shot I'll push it on harder. Is there a pin out for the RJ45/OBDII connection? It'll be helpful with pinning out the connector if this doesn't work. It's a cheap cable from China, so maybe something isn't seated right. |
04-23-2016, 04:40 PM | #1275 | ||
Rep 5,262
If you can lay down and look at the car side of the obd2 you can check if the female side of the sockets all look good Also a sign that it's plugged in is that the car will make a few noises when you plug it in like priming the fuel pump |
04-23-2016, 06:45 PM | #1276 | |
Rep 1,202
Not sure why I hadn't done this before but I pulled the sides off the OBDII plug and bam, the green/white wire is disconnected. Guess I'll have to solder it back on now. If anyone is curious I found the pin out in a build guide: http://f30.bimmerpost.com/forums/att...0&d=1339310761 I'm actually relieved, as this is an easy fix. Thanks again for the help. Last edited by Beartato; 04-23-2016 at 06:50 PM.. |
