02-06-2018, 10:48 PM | #1 |
Rep 57
235/40/18 square setup question
Hello,
I would like a 235/40/18 square setup on my 2016 M235i xDrive. Hoping to use Michelin Pilot Super Sport rubber. Stock ride height now, but considering a mild drop in the future. Trying to avoid spacers and fender rolling if possible. Considering two wheels: - Enkei Raijin 18x8 +32 - TSW Nurburgring 18x8 +35 Anyone running any of these setups? Will they work without rubbing? Thanks Last edited by SpudGT; 02-06-2018 at 11:03 PM.. Reason: Change title |
02-06-2018, 10:57 PM | #2 |
Rep 57
TSW Interlagos
I saw this thread with a very similar setup:
http://www.2addicts.com/forums/showthread.php?t=1245558 Looks like it worked well ... |
02-11-2018, 08:49 PM | #3 |
Gangnam Member
229
Rep 136
While not a perfect match I do have some information that may help. I have the 18x8 +35 TSW Nurburgring wheels on my current RWD 228i and I had them on my previous RWD 228i.
The previous car had the 702 M-Sport suspension which is a 10mm drop from stock. While I had only 225's vs your desired 235's there was plenty of clearance. My current 228i has the M Performance Suspension which is 20mm down from stock. Same TSW wheels but they are now my winter wheels and I have 225's in Michelin Alpin PA4 tires. Again no issues and I can't imagine a 235 would not fit as well. YMMV. Just thought I'd add some similar experience.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC |
SpudGT27.00 |
02-18-2018, 04:45 PM | #5 |
Rep 57
Went with VMR
Ended up going with a square VMR setup:
- VMR V804 | Hyper Silver - 18x8.0 ET42 - 235/40/18 Michelin Pilot Super Sport - Stock suspension and alignment Really happy with the fitment, no rubbing noticed so far. Dinan springs are on the way ... Saved a bit of weight as well: - each stock wheel and tire was 45.4 pounds - new VMR wheel and tire is 42 pounds. See pictures here: http://www.2addicts.com/forums/showp...&postcount=378 |
04-07-2018, 11:56 AM | #6 |
Rep 44
What is the offset of the stock wheels? I’ve been digging around trying to figure it out. I want to run the 235/40 on stock wheels. My understanding is there’s only about a 5 mm gap. Which would be pretty much taken up by the extra 5 mm on the inside when going from a 225 to a 235 mm wide tire
04-07-2018, 01:13 PM | #7 |
3708
Rep 3,621
Stock wheels are 7.5Jx18 ET45 in the front, 8Jx18 ET52 in the rear (or the same as the front if not staggered).
The 7.5" wide wheels will only fit a maximum width of a 225/40-18 tyre, 8" to 9.5" wide is required for 235/40-18 and 245/35-18 tyres, 8.5" to 10" wide for 255/35-18 tyres. |
06-20-2018, 10:33 AM | #8 | |
Rep 44
Current: F22 228i M Sport Mineral Grey, E84 X1 xDrive35i M Sport Alpine White, R53 Mini Cooper S JCW Indi Blue
Previous: E46 330i M Sport Orient Blue, and a bunch of non BMW mostly crap cars, except the CRX, which was an absolute blast |
06-20-2018, 11:40 AM | #9 | |
Rep 57
After several months of driving and a couple AutoX events there is no sign of rubbing. I can't say if my camber settings contribute to the lack of rubbing, but the tires don't look dangerously close to the fenders. The clearance between the front tires and the front struts seems tight, but no issues. |
MsportyX3525.00 |
