2Addicts | BMW 2-Series forum Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics Steering Wheel Channel Select Option?
      01-08-2020, 11:49 PM   #1
Edslittleworld
Edslittleworld's Avatar
33
Drives: 2017 M240i (6MT)
One pet peeve I have with my 2017 M240i are the audio controls. Is there any solution to install/reflash to have a "channel select" control on the steering wheel. I am a channel surfer and hate having to reach across the dash every time to change to the next song (I usually use USB-loaded songs). Plus, my in-dash channel select button is starting to stick out like it's been used/tweaked a bit too much. I'd sure hate to have to repair that system ($$$??).
Note: My same year Toyota Tacoma has both a touch screen control AND a channel select control on the steering wheel. Nice for both convenience and redundancy as the car ages. I think the Germans could learn from Japanese interior designers.
Any help would be appreciated!
      01-09-2020, 08:16 AM   #2
ngl
ngl's Avatar
118
Drives: BMW 228i
You can use the scroll and push to select next song. It's not perfect, but it is on the steering wheel.
Quaife LSD | BC Racing Coilovers | H&R ARB | F8x LCA+TS | Wiechers Strutbar | Mishimoto CAI | Mishimoto Oil Cooler | Mishimoto Oil Catch Can | Mishimoto FMIC | VRSF DP | Masata TIC | Masata CP | DV+ | Custom Kline Exhaust | GTS Style Roll Cage | Sparco Evo QRT | Brey-Krause seat mounts | Schroth Profi 2 ASM 6p | 10" Android HU| xHP Stage3 | BM3 | RaceCapture Data Logger
      01-11-2020, 08:14 PM   #3
Edslittleworld
33
True, but I like the random feature on my other car audio systems. Thanks for the answer, tho!
      01-12-2020, 10:24 PM   #4
redcars
Drives: 228xi
What's weird is it doesn't wrap from the last preset back to the first preset. Should be an easy fix. I know the "next" button in the center stack does that. Also strange is that the list of presets on the center screen doesn't scroll with the scroll button on the steering wheel. Only responds to the iDrive wheel.
      01-17-2020, 09:14 AM   #5
KrispyM240
KrispyM240's Avatar
Drives: 2017 M240i 2015 M4
That has been my biggest gripe since day 1 of owning the car. Honestly, I think I may try to tear that side of the steering wheel apart and switch the wiring from the volume buttons to the scroll wheel. Chances are the I/O will be different on those though so we'll see if it will work but scrolling up or down to raise and lower the volume makes more sense to me
      01-20-2020, 11:11 AM   #6
damianbmw12
Drives: 2020 BMW M240xi & 2004 330Ci
Cool idea be curious if you have success.
      02-03-2020, 09:16 AM   #7
ngl
ngl's Avatar
118
Drives: BMW 228i
It will not work, the buttons are recognized by voltage resistance, they are not physically wired to the head unit.
Not saying this is possible ( don't know ), but you are more likely to succeed in changing their function by coding rather than connecting them elsewhere.
