09-21-2017, 10:27 PM | #1 |
Rep 12
Need Help With Upgraded Wheels/Tires for M235i
Sorry for starting another thread, but I could use some advice, and I still have questions after scouring old threads. If you have knowledge or ideas about any of the following, I'd appreciate your thoughts.
Thanks! |
09-24-2017, 04:56 AM | #2 | |
Rep 145
http://www.tyresizecalculator.com/ty...ize-calculator Another web page I found useful to compare your existing wheel/tire combination against your proposed wheel/tire combination: https://rimsntires.com/specspro.jsp Hope this and other posts helps. |
09-25-2017, 10:25 AM | #4 |
Rep 2,873
What size wheel is that on - is it an 8" wheel at each corner? I'm considering going to a square setup myself so I can rotate tires, but had heard the same thing the OP is saying (can't fit 245's up front w/o other unwanted mods).
09-25-2017, 05:51 PM | #5 |
Rep 12
Interesting. I have the same question as Maynard--are you using 8-inch or 8.5-inch wheels? Also, what tires are you running? (I ask because some tires run wider than others, and every mm matters when things are as tight as they are in the 2 series.)
10-19-2017, 02:48 PM | #6 | |
sillyphuck
17
Rep 44
Drives: 2015 M235i
Niche Monoblock Apex 19" Front: 19"x8.5" et35 MPSS tires 235/35/19 Rear: 19"x9.5" et40 MPSS tires 265/30/19 Finish: Brushed clear Stock suspension, no spacers. No rubbing at all on the inner wall of tires or rims. Rubs on the front when i do a very sharp right hand reverse maneuver. Super minimal though. hope that helps |
10-19-2017, 05:13 PM | #7 |
Rep 6,934
Drives: 2018 M2 AW DCT
I'm running BBS CH-Rs all around in 225/40/18s. The BBSs have an offset of 40. 225X40X18 are the preferred size on an 18X8 wheel. My tires are Michelin A/S 3+. I really like the setup.
Maynard3848.00 |
Tags |
apex, square, staggered, wheels |
