01-12-2016, 06:17 PM | #1057 |
Rep 444
Probably keep the buckles. Sucks on the tpms. I usually lower tire pressure at the drag strip, but this car is stuck in Comfort mode if the tire pressure isn't ideal. Might have to resort to the tpms pipe bomb.
Quickest Stock Turbo F8x In The World
01-12-2016, 08:35 PM | #1058 |
Rep 444
Got everything done besides the FEM_BODY. Can't get it to read.
Here are my error codes CAFD_00000DBD_001_007_000 Fehler: CPS read from ECU "ECUId:AMPH_0x37" failed! [C070] negative response error: code: TIMEOUT P2/T2 occurred description: P2 timeout on Service RDBI_CPS has error in result: [Severity=2051][ErrorCode=58640][ErrorCodeDescription=resource not available][VendorCode=2142][VendorCodeDescription=P2 timeout occured]; ECU: AMPH_37_ETHERNET severity: ERROR [2130765072] FEM_BODY [40] [V359060] readCPS o.k. CAFD_00000794_014_040_122 Fehler: File for "cafd_00000794-014_040_122" not found! [C012] Thought the updated PSDZDATA would fix it.
01-12-2016, 08:39 PM | #1059 | |
Rep 5,262
What psdzdata are you using? |
01-12-2016, 08:40 PM | #1060 | |
Rep 5,262
01-12-2016, 08:45 PM | #1061 | |
General
10443
Rep 40,762
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-12-2016, 09:21 PM | #1062 |
Rep 444
Did some digging around, going to try
psdzdata / swe / CAFD
01-12-2016, 09:22 PM | #1063 |
Rep 444
Using 57.3. Previously used 57.2. Everything coded fine besides the FEM_BODY
01-12-2016, 09:41 PM | #1064 |
General
10443
Rep 40,762
01-13-2016, 04:50 AM | #1067 | |
Rep 5,262
01-14-2016, 08:44 AM | #1068 |
Rep 264
anybody able to code "easy access" where the seats slide back when you turn off the car and then back to its original position when starting the car?
Current: 2019 X3 M40i and 2018 330i
Previously: 2016 M235i Convertible and 2016 X4 28i and many non-BMWs |
01-17-2016, 09:12 AM | #1069 |
Rep 47
Quick question. I am looking to VO code in Enhanced BT. If I do that through FA and apply the code, will all of my current FDC changes in HU_NBT2 will revert back to default?
01-17-2016, 09:14 AM | #1070 |
General
10443
Rep 40,762
You mean FDL Code Changes, and yes.
01-17-2016, 04:09 PM | #1072 |
Rep 47
First, shawnsheridan and pikcachu Your coding expertise is awesome.
Just picked up the car and... Removed 8S4 (Decoding Variable Light Distribution) Swapped 6NH to 6NS (Enhanced Bluetooth) Removed seatbelt alarms for Driver and Passenger Open / close mirror with FOB Delayed mirror close to 300ms Driving halos to 50% Radio/Nav off with open door Door handle LED while backing Emergency brake mode to blinking DVD and Video Format settings Removed disclaimers Changed startup logo Edited office message settings Added TPMS settings Added Google local voice search Added digital speed GPS Sync for clock Unlock doors when engine off Own ring tone Now time to go drive it Last edited by cth6; 01-17-2016 at 04:34 PM.. |
01-17-2016, 05:20 PM | #1073 | |
Rep 5,262
01-17-2016, 06:39 PM | #1074 | |
Rep 444
http://f30.bimmerpost.com/forums/sho....php?t=1133203
01-17-2016, 08:04 PM | #1075 |
Rep 47
It still chimes when the car starts, but as soon as you drive off no alarming. The cluster light still shines showing seatbelt open. That is exactly what I was looking for.
The only thing I am having issues with is enhanced bluetooth. VO coded it. I can't have two phones active at the same time. Acts just like the 6NH did. Trying to find instructions on how it should work if you bought it. The only ECU I coded was HU_NBT2 after applying the 6NS. Last edited by cth6; 01-17-2016 at 08:46 PM.. |
01-18-2016, 11:54 AM | #1076 |
Rep 554
Question about "Auto Folding Mirrors upon Locking"...do they UNFOLD when you start the car?
The Stable
2015 BMW M235i | 2014 Porsche Carrera S | 2017 Porsche Macan GTS | 1996 Porsche Carrera 4S |
01-18-2016, 02:24 PM | #1077 | |
Rep 47
As a fail safe the car automatically unfolds the mirrors at about 10 MPH. Someone probably has the exact speed. Last edited by cth6; 01-18-2016 at 02:42 PM.. |
01-18-2016, 02:40 PM | #1078 |
Rep 47
I have been playing a bunch with the coding on the car and wanted to share my experience. Not sure if there are changes to the 2016 cars that may impact how some of these codes work.
To start ... '16 M235i Coupe, Technology Package (ZTP), Driver Assist Package (ZDA) Order Options - 1CA, 2TB, 2VB, 3AG, 3DZ, 302, 319, 322, 4FT, 4NE, 403, 423, 430, 431, 441, 459, 488, 493, 494, 508, 521, 522, 524, 534, 563, 6AC, 6AE, 6AK, 6AM, 6AP, 6NH, 6WA, 609, 655, 676, 697, 8KL, 8S4, 8TN, 840, 9AA, 925 VO Coding - Remove 8S4 - Works VO Coding - Change 6NH to 6NS - Works (Just need to remember to go into Settings, Connections, Bluetooth, in the menu if you scroll right while Bluetooth is highlighted you see the setting to configure bluetooth. Under there I found Telephone 2. All I had to do was check it and then go back to my secondary phone and select phone 2 as opposed to phone 1.) FDL Coding - The good
The questionable
The ugly
Just need to figure out iPod video now. Last edited by cth6; 01-22-2016 at 04:04 PM.. Reason: Updated due to additional testing |
