Home audio guys - suggestions for phone controlled receivers? |
03-02-2019, 08:17 PM | #1 |
11585
Rep 12,725
sup dudes. let me preface this by saying that i'm not an audiophile by any stretch, but i want something better quality (and no hassle) than a blu tooth speaker i have to lug around and charge.
that being said, i want speakers wired underneath the overhang of my house in the backyard, and speakers wired into the garage. i don't need them both to be operating at the same time, but if i'm in my backyard (or garage), i want to just be able to open an app, connect, and hit play, and be able to control the volume with my phone. is there a bigger advantage to wifi or bluetooth? is there anything out there like that? it doesn't have to be super cheap, but i'm not looking to blow a bunch of money, either.
Instagram; @roastbeefmike
03-02-2019, 08:42 PM | #2 |
Rep 3,225
I’ve used Sonos throughout my house, they are also portable so you can move them around should you like. They are operated by an app on the phone and whilst they’re not the best speakers in the world the certainly do me and I am a music lover not an audiophile.
Grumpy Old Man6476.50 wrickem2101.00 |
03-02-2019, 08:51 PM | #3 |
Rep 1,004
Another vote for Sonos- I believe they just announced an outdoor enclosure too.
03-02-2019, 08:57 PM | #4 |
9154
Rep 14,522
most of the newer receivers have blutooth capability so it's pretty easy to play music using your phone. I do it all the time. as far as speakers you could get outdoor wireless speakers that way you don't have to run wires to both outside your house and your garage. check out avsforums.com. plenty of talk about the variety of speaker choices you can go with along with the receivers to support them
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
roastbeef11584.50 |
03-02-2019, 09:34 PM | #6 |
11585
Rep 12,725
i don't mind wiring speakers... the whole point of wiring them is so i don't have to worry about charging them.
03-03-2019, 06:02 AM | #7 |
Rep 1,966
I actually ran extension cords under my eves and hung a pair of Sonos 1's up there permanently for the back yard. I tucked them up really close so they are kept dry. The Sonos 1's are humidity protected so you can use them in the bathroom. I've had them out there two years and they work great. My back yard is 60' wide and about 40' from the back of the house to the neighbours fence. They won't give you concert volume but work really well for the space. I have another set on the covered front porch. Great sound and Sonos software is really easy and versatile I've attached a couple of pic so you get the idea. The mounting brackets are available at Best Buy and are made for Sonos and work great. Pics are aren't great, sorry.
I've included a close up of one of the speakers and the plastic case I used to run the wires, it can be painted I just haven't gotten around to it. Also included a pic of the brackets I used. I like them because they can tilt and swivel for optimum placement. I like the Sonos 1 because they can be used in pairs for stereo which I've done on the front porch and back yard. Last edited by Grumpy Old Man; 03-03-2019 at 06:17 AM.. |
03-03-2019, 07:23 AM | #9 |
Rep 1,966
03-03-2019, 07:29 AM | #10 |
11585
Rep 12,725
wiring is fine. all i want is to be able to crack a beer in my backyard, pull out my phone, and have some tunes/podcasts going with a couple quick taps.
i looked on the sonos website for outdoor speakers, and it looks like what they have is "coming soon." so maybe they are between versions of speakers?
03-03-2019, 07:41 AM | #11 | |
Rep 1,966
The other option if you want to run speaker wires is the Sonos Connect or Connect Amp if you don't have a home audio system with a second set of speaker outputs for your outdoor speakers. You can use regular outdoor speakers this way and use the Sonos system to control them. That was my previous set up and worked great. Honestly though for the money the Sonos Play 1 are excellent and as long as you have them tucked up under the eve or so they are out of the weather they work great. We get -20 degrees here and they haven't been bothered, and we get up into the high 90's with humidity in the summer. Like I said, over 2 years now and zero issues. |
03-03-2019, 07:46 AM | #12 |
Rep 1,004
For that you can just get a decent Bluetooth speaker and plug it in to the usb charger. Then take your time deciding what you want.
We use Sonos because that was about the only good wireless (again speaker wireless, not power wireless) option when we started, and we’ve kept staying with them as our system has grown. The app is good, can stream anything on our computers or phones, and can stream several dozen radio stations too. Also can connect to speaker output from TV to be either surround or just have tv sound throughout the house (sports). |
roastbeef11584.50 |
03-03-2019, 07:49 AM | #13 |
11585
Rep 12,725
there is a small overhang in the backyard, but its about 2', so nothing super sheltering- just enough to keep them from getting soaked.
i figured i would have to get an amp to run the two sets of speakers i had in mind, i just want them to be selectable. $700 might be a little more than i wanted to spend on speakers alone...
03-03-2019, 07:59 AM | #14 | |
Rep 1,004
roastbeef11584.50 |
03-03-2019, 08:06 AM | #15 |
Rep 1,966
So if you go the Sonos route, you'll need the controller, the Play 1's are a seriously good deal at about $150 US each. The controller is about $350 US, you not cheap but it will give you what you want, the sound is really good and works well outside.
2000cs3496.50 |
03-03-2019, 08:56 AM | #16 | |
Rep 1,004
We have a few Play1s, a pair of Play3s, a pair or of Play5s, a sound bar and a sub. We moved a year ago and the new house has a wired system in several rooms, so we used the Sonos to extend that to other rooms. Don’t need the sub and sound bar so they are in storage - this house had surround system already wired/installed. |
03-03-2019, 09:08 AM | #17 | |
Rep 1,966
03-03-2019, 10:22 AM | #18 |
Rep 774
Drives: E90 335i & E60 550i
Sonos has not announced any AC (aka active) powered outdoor speakers. What they have announced are passive outdoor speakers which would require low voltage wiring to a Sonos Amp. They partnered with a speaker manuafacturer called Sonance to sell their outdoor rated passive speakers. They will retail for $799/pair and will require that you power them with a Sonos Amp at $599 via speaker wire.
https://www.crutchfield.com/S-cryded...SABEgLCIfD_BwE
Pure S2 Turbos | Vargas Outlets | RB Inlets | OEM SS Kit & Performance Steering Wheel| LCI Rear Conversion | Euro Xenons | RD Sport Quad Exhaust | Spearco Intercooler | Cobb V3 | MORR VS7 | KW V3 | H&R Sways | Mtech Bodykit | Vorsteiner CF Hood, CSL Trunk & Front Lip | Quaife LSD | Rotora BBK | GruppeM Intake | Forge UK DV | AR Design Catted DP's
2000cs3496.50 |
03-03-2019, 10:30 AM | #19 | |
Rep 1,966
https://www.sonos.com/en-ca/shop/out..._rid=111905570 |
03-03-2019, 11:12 AM | #20 | |
Rep 1,004
03-03-2019, 11:47 AM | #21 |
2006 TIME Person Of The Year
9720
Rep 6,445
The SONOS app interface is far better than any AV receiver app.
Putting a SONOS Play1 outside is definitely not recommended by SONOS. It may work, but be aware that you're coloring outside the lines. I usually recommend utilizing a mono signal for outdoor audio installations (if possible). Because you're not usually even remotely centrally located between the speakers, and usually relatively far from the speakers, stereo separation can do more harm than good. Even if you were to use multiple Play1s, I'd still keep them as individual units rather than pairing them up. Someone has already mentioned this, but I'd suggest a SONOS ConnectAmp with a pair or two of outdoor speakers.
03-03-2019, 12:14 PM | #22 |
11569
Rep 11,136
I have recently switched over to 100% Sonos. I have close to 10 zones, with a range from Play 1s, Play 5s, a few Sonos Amps and built-in ceiling speakers and outdoor speakers. Works well.
The cheapest way for you to get started is probably just buying a Sonos Connect (you can picked them up used for $200+ or so) and hooking that up to an amplifier you have lying around. Hook that amp up to your outdoor and garage speakers and off you go. |
