03-01-2019, 11:31 AM | #1 |
Rep 448
O.Z. Leggera HLT
Looking at O.Z. Leggera HLT 18x8 45mm offset for a "square" set up on an incoming M240i
https://www.ozracing.com/alloy-wheel...ch/leggera-hlt Some questions: TUV. Are these wheels (i.e. this specific model) TUV certified? Offset. I want to be sure the wheels fit with no rubbing and good clearance. Is the 45mm offset the right offset? Ideally, I want them to be as close to the fenders as possible without any chance of rubbing. Tire Width. How wide can I go tire-wise? Should stay with 225s? Are 235s all around "safe" (no rubbing, interference)? I do not want to deviate from normal factory-recommended camber. Tires. Opinion of the Michelin Pilot Sport PS4 vs Super Sports or PS2s? I have and have had the SS and PS2s. This will be for summer driving as I have dedicated snow wheels/tires for winter here in Seattle. Brake Dust. I have had lots of BMWs and the factory brake pads throw massive dust. Opinion of ceramic coating on the wheels to help keep them clean / easier to clean? Thanks very much. |
03-01-2019, 12:47 PM | #2 | |
Rep 823
03-01-2019, 01:14 PM | #4 | |
Rep 448
Thanks!
Out of curiosity, which wheels are the ones shown in the photos? Would a spacer help, particularly if I used 225/40s on the rear? Thanks again. |
03-03-2019, 10:15 AM | #6 | |
Rep 448
thanks & q
If I go with the HLTs, I may use a 5mm spacer. Any rubbing issues with the 245s? did you need to adjust the camber? |
