Csf Bmw B58 High-performance Heat Exchanger Now Available! *** New Product *** |
02-14-2019, 02:50 PM | #1 |
Rep 190,805
The BMW F-series B58 engine is found in a wide array of BMW vehicles (M140i, M240i, 340i, 440i). The motor is similar to the S55 engine found in the latest generation F8x M3/M4 (and new M2 competition) in that it has an indirect water-to-air charge cooling system with a supplemental front mount heat exchanger to cool the water that circulates through the charge cooler. However, unlike the S55 motor, the BMW B58 charge cooler is built into the plastic intake manifold housing. In the meantime of continued development of its high-performance manifold charge cooler, CSF has first released their new BMW B58 heat exchanger for BMW F-Series vehicles. CSF’s new high performance B58 heat exchanger drastically reduces water temperatures in the charge cooling cycle, which in turn reduces and stabilizes the intake air temperatures of the engine. With many unique features, included accessories, and of course, industry-leading performance, it’s without a doubt the best option on the market for every consumer whether it be for a daily driver or a high-performance race car. CSF’s new BMW B58 high performance heat exchanger in mirror polished finish (CSF #8131) Through several prototypes, CSF has come up with a winning design, and has been able to fit the absolute largest & most efficient cooler into the vehicle. Designed to fill the entire area in front of the cooling system housing and underneath the OEM X-brace. Includes detachable rock guard for extra protection. The original OEM B58 heat exchanger is a 1-row unit that is 27mm thick. In comparison, CSF has used its industry exclusive world’s largest 2-row core (68mm) with CSF’s B-Tube technology. A unique tank design allows the larger CSF core to still fit into the OEM cooling system housing. The OEM heat exchanger is confined within the plastic cooling system housing. The thicker CSF 68mm core protrudes out of the plastic cooling system housing and installs with no modifications. Another critical feature of the CSF BMW B58 high-performance heat exchanger is its unique triple-pass flow design. The water traveling through the upgraded heat exchanger flows through the radiator three times before exiting the cooler and flowing back into the manifold charge cooler. This ensures that the outlet water temperature of the heat exchanger is the absolute lowest it can be. The OEM design, as well as more expensive aftermarket designs, all have single-pass flow structures. 3x the cooling compared to the OEM! Exclusively from CSF You can see from the data in the chart how quickly intake air temperatures (IAT ℉) start to rise when using the OEM heat exchanger. Through only one gear pull in 4th gear at wide open throttle (WOT), IAT’s shot up by 15 degrees ℉ and will continue to climb to the point of heat soak when using the OEM heat exchanger. In comparison, the high-performance BMW B58 heat exchanger from CSF keeps temperatures stable and consistent at ~95 ℉. This is due to the three key design characteristics of the CSF unit; increased capacity, triple-pass design, and CSF’s ultra-efficient B-tube core technology. CSF’s high performance / upgraded heat exchanger for BMW F-series B58 engines comes standard with a detachable rock guard and is also available in 2 finishes. Semi-Gloss Black – CSF# 8131B Polished – CSF# 8131 Engine side of the CSF BMW B58 heat exchanger for F-series vehicles. Shown in black (#8131B) – take notice of the 100% TIG welded construction and CNC machined brackets and fittings. As the 3.0 Liter B58B30M0 turbo engine platform continues to be developed by the high performance industry and more power is extracted from the engine, CSF’s high performance heat exchanger for the BMW B58 engine will be a critical component to keeping the vehicle charge air cool, and out of limp mode. The CSF BMW B58 upgraded heat exchanger for F-series vehicles will be especially important to install in upgraded turbo applications and/or vehicles running high performance tuning software. Bonus: Pair this heat exchanger with one of CSF’s high performance F-series radaitors (#7080 for manual transmission / #7081 for automatic transmission) CSF BMW High Performance BMW B58 Heat Exchanger Specifications Core size: 524mm Length x 478mm Height x 69mm Wide 68mm 2-row core with CSF’s B-tube technology (world’s largest 2 row core) 6.5 mm multi-louvered fin height Triple-pass flow design Included / detachable rock guard OEM CNC Machined mounting location pins and brackets Direct Plug and Play, including CNC machined “Quick-connect” inlet/outlet water fittings No Modifications needed to install. What’s Included? CSF BMW High Performance B58 Heat Exchanger Hardware Kit Detachable rock guard OEM Part Number #17118741830 CSF Part Numbers Semi-Gloss Black – CSF# 8131B Polished – CSF# 8131 Verified Application Fitment 15-18 BMW 120i, 125i, M140i(x) (F20) 15-18 BMW 120i, 125i, M140i(x) (F21) 15-18 BMW 220i, 230i(x), M240i(x) (F22) 15-18 BMW 220i, 230i(x), M240i(x) (F23) 14-18 BMW 320i(x), 330e, 330i(x), 340i(x) (F30) 14-18 BMW 320i(x), 330i(x), 340i(x) (F31) 15-18 BMW 320i(x) GT, 330i(x) GT, 340i(x) GT (F34) 15-18 420i(x), 430i(x), 440i(x) (F32) 15-18 BMW 420i, 430i(x), 440i(x) (F33) 15-18 BMW 420i(x), 430i(x), 440i(x) Gran Coupe (F36)
02-15-2019, 11:33 AM | #2 |
Rep 913
Obvious question is price since this compares against the Wagner heat exchanger.
02-15-2019, 11:57 AM | #3 |
Rep 274
Definitely intrigued, need something else to play with on my car. One question, why does it say you can pair this with a CSF radiator? Isn’t the heat exchanger the radiator?
02-15-2019, 01:08 PM | #5 | |
Rep 504
a heat exchanger is not always a radiator (it could be an oil cooler, intercooler, trans cooler, etc) typically a radiator of a car is known for cooling engine water. this B58 cooler since it’s cooling the charge cooler water, we’ve called it a heat exchanger / we don’t want to confuse people into thinking that they’re buying the engine radiator. - also, we do make the high performance engine radiators for the same car #7080 (manual) /#7081 (auto) |
02-15-2019, 01:14 PM | #6 | ||
Rep 274
Understood, my question is you wouldn't buy both though. It's one or the other correct? |
02-15-2019, 02:26 PM | #7 |
Rep 3,497
Do you have a link to a page on your site that shows this B58 radiator?
02-15-2019, 04:12 PM | #8 |
Rep 274
If you google the product number you can find it easier on other sites. CSF website isn't the most clear. Here is one link I found for the automatic.
https://www.evasivemotorsports.com/s...BoCodIQAvD_BwE |
dradernh4401.00 |
02-15-2019, 04:14 PM | #9 | |
Rep 207
Built B58 // instagram: tyler.genter
02-15-2019, 04:58 PM | #10 | ||
Rep 274
02-15-2019, 06:48 PM | #11 | |
Rep 3,497
I'll follow-up here once I hear back from Evasive.
JD11937129.50 |
02-16-2019, 10:32 AM | #12 | |
Rep 3,497
"Bonus: Pair this heat exchanger with one of CSF’s high performance F-series radaitors (#7080 for manual transmission / #7081 for automatic transmission)" http://csfrace.com/the-ultimate-bmw-...eat-exchanger/
02-18-2019, 02:23 PM | #13 | |
Rep 504
Just wanted to clear a few things up. 1) There was a mistake in our press release about the #7080/#7081 fitting the B58 engine as the water radiator - this will be getting removed from the news story in the next 24 hours. 2) We are working on an upgraded B58 engine water radiator, but not yet released. 3) the fitment for the following 2 models. CSF #7081 (A.T) OEM # 17117618807 Year Model Sub-Model Chassis Code 10-18 125i 5 doors F20 10-18 M135i(X) 5 doors F20 14-18 116i 5 doors F20 14-18 118i 5 doors F20 14-18 125i 5 doors F20 14-18 M135i(X) 5 doors F20 10-18 125i 3 doors F21 10-18 M135i(X) 3 doors F21 14-18 118i 3 doors F21 12-17 218i Coupe F22 12-17 220i Coupe F22 12-17 228i(X) Coupe F22 12-17 M235i(X) Coupe F22 14-17 218i Convertible F23 14-17 220i Convertible F23 14-17 228i(X) Convertible F23 14-17 M235i(X) Convertible F23 11-18 320i(X) Sedan F30 11-18 328I(X) Sedan F30 11-15 335i(X) Sedan F30 11-15 Hybrid 3 Sedan F30 14-18 318i Sedan F30 11-15 320i(X) Touring F31 11-18 328i(X) Touring F31 11-15 335i(X) Touring F31 12-16 320i(X) Gran Turismo F34 GT 12-16 328i(X) Gran Turismo F34 GT 12-16 335i(X) Gran Turismo F34 GT 12-17 418i Coupe F32 12-17 420i(X) Coupe F32 12-17 428i(X) Coupe F32 12-17 435i(X) Coupe F32 13-17 420i Convertible F33 13-17 428i(X) Convertible F33 13-17 435i(X) Convertible F33 13-17 418i Gran Coupe F36 Gran Coupe 13-17 420i(X) Gran Coupe F36 Gran Coupe 13-17 428i(X) Gran Coupe F36 Gran Coupe 13-17 435i(X) Gran Coupe F36 Gran Coupe CSF #7080 (M.T) OEM # 17117600520 Year Model Sub-Model Chassis Code 10-18 118i 5 doors F20 10-18 120d 5 doors F20 10-15 125d 5 doors F20 10-18 125i 5 doors F20 10-18 M135i 5 doors F20 14-18 116i 5 doors F20 10-18 118i 3 doors F21 10-15 125d 3 doors F21 10-18 125i 3 doors F21 10-18 M135i 3 doors F21 14-18 116i 3 doors F21 14-18 120d 3 doors F21 14-18 120i 3 doors F21 12-17 218i Coupe F22 12-17 220d Coupe F22 12-17 220i Coupe F22 12-17 228i Coupe F22 14-17 218i Convertible F23 14-17 220d Convertible F23 14-17 220i Convertible F23 14-17 228i Convertible F23 11-16 316d Sedan F30 11-18 318d Sedan F30 11-18 320d(X) Sedan F30 11-18 320i(X) Sedan F30 11-18 325d Sedan F30 11-18 328i(X) Sedan F30 11-16 335i(X) Sedan F30 14-18 318i Sedan F30 11-15 316d Touring F31 11-15 318d Touring F31 11-18 320d(X) Touring F31 11-15 320i(X) Touring F31 11-18 325d Touring F31 11-15 328i(X) Touring F31 11-15 335i Touring F31 14-18 318i Touring F31 12-16 318d Gran Turismo F34 GT 12-16 320d(X) Gran Turismo F34 GT 12-16 320i(X) Gran Turismo F34 GT 12-16 325d Gran Turismo F34 GT 12-17 420d(X) Coupe F32 12-17 420i(X) Coupe F32 12-17 425d Coupe F32 12-17 428i(X) Coupe F32 12-17 435i(X) Coupe F32 13-17 420d Convertible F33 13-17 420i Convertible F33 13-17 425d Convertible F33 13-17 428i Convertible F33 13-17 435i(X) Convertible F33 13-17 418i Gran Coupe F36 Gran Coupe 13-17 420d(X) Gran Coupe F36 Gran Coupe 13-17 420i(X) Gran Coupe F36 Gran Coupe 13-17 425d Gran Coupe F36 Gran Coupe 13-17 428i(X) Gran Coupe F36 Gran Coupe 13-17 435i(X) Gran Coupe F36 Gran Coupe 13-17 i3 60aH Rex i3 |
02-19-2019, 01:45 PM | #14 | |
Rep 207
Thank you for clarifying that information Mike
