09-28-2018, 08:24 AM | #486 |
Rep 296
Just bought a set of V801's in Sunken Treasure in staggered fitment, cannot wait for them to get here!
18x8.5 et35 front 18x9.5 et45 rear Stock suspension VMR is suggesting I stick with a 225/40/18 in the front to ensure to rubbing. I see conflicting info on the fitment of the 235/40/18. I'd really like a 235 if possible. Would moving to a 235/35/18 clear suspension and not rub the fenders? EDIT: Looking at TireRack.com it shows Stock MPSS 225 having a treadwidth of 7.9 The MPS4 225 look to be narrower at 7.7 The MPS4 in 235 shows to be 8.1 I wonder if a MPS4 235/40/18 would fit in front on stock suspension with no rubbing since it runs a little narrow. Last edited by tennisfreak; 09-28-2018 at 08:57 AM.. |
09-28-2018, 10:59 AM | #487 | |
Rep 643
09-28-2018, 08:39 PM | #489 |
Rep 503
Please post pics! I am very curious to see the "Sunken Treasure" color on Estoril Blue, the best color ever!
10-02-2018, 05:12 PM | #490 | |
General
2042
Rep 25,989
VMR|Wheels | 714.442.7916 |
10-18-2018, 08:42 PM | #492 |
Rep 58
On stock suspension would 18 by 9.5 vmr v710 wheels with an offset of 45mm fit on my 2017 bmw 230i with track package and m sport package. And for the front 18 by 8.5 with an offset of 35mm.
And should i get same offset front and back even if my rear rims are an inch wider. |
10-19-2018, 04:15 PM | #494 | |
General
2042
Rep 25,989
Any day now! Looking forward to seeing some pictures.
10-20-2018, 01:42 AM | #495 |
Rep 26
Placed an order for a set of V710’s in the satin bronze color way, which will be going on an alpine white 235. Stock suspension as I am waiting for Black Friday sales to pick up the Dinan suspension parts...now to carefully calculate my tire wear and time it just right to use up as much of the old 18” tires before the 19”s get here.
10-21-2018, 08:49 PM | #496 | |
Rep 58
10-22-2018, 01:08 PM | #497 | |
General
2042
Rep 25,989
10-22-2018, 01:19 PM | #498 | |
General
2042
Rep 25,989
11-05-2018, 02:35 PM | #499 |
Rep 274
I’m sure you have been asked this 100 times so I apologize in advance.
Do you have any customers running 19x8.5 et35 v710ff 225 tire front and 235 back with H&R sport springs without rubbing on an m240xi? |
11-05-2018, 05:19 PM | #500 |
General
2042
Rep 25,989
We have customer's running a wide variety of lowering springs and coilovers. Because your car is an xDrive car, you'll want to run either 225 on all four corners of a square setup. You can also run a 19x9.5 ET45 with a 255/30/19 in order to keep your rolling diameters in check.
11-06-2018, 07:25 PM | #501 | |
Rep 274
11-07-2018, 05:15 PM | #502 | |
General
2042
Rep 25,989
The recommended fitment for the front would be 19x8.5 ET35 with a 225/35/19 tire.
11-07-2018, 07:02 PM | #503 |
Rep 555
So I am about due for new tires all around, I am seriously thinking of biting the bullet and just going for 235/35/19F and 265/30/19R
I am currently on stock suspension, but probably in the next few months plan on going with Dinan springs. I am running VMR V804 19x8.5 et35F and 19x9.5 et45R, currently bone stock. I am a little worried about rubbing under harder driving/suspension compression. I think before lowering etc, I would probably do some mild fender rolling, and get the M4 LCA/TS for a bit of extra negative camber up front. I noticed a couple of people have gone up to these sizes, so curious on any inputs on anyone that has run this for a bit, if it is feasible? Or am I heading for a world of headaches?
11-08-2018, 06:53 AM | #504 | |
Rep 115
I've had these on for the last few months with zero rubbing on the street. During this past weekend's trip to Tail of the Dragon, I finally received some rubbing (front and rear) during some very hard cornering. I haven't pulled the wheels off to see where it was rubbing, but I'm going to guess on the fender liner itself. It was very very mild, and this was during driving the car at 9/10's on some fairly crazy roads with bumps, dips, banked corners, etc.
2014 M235i
11-08-2018, 07:40 AM | #505 | |
Rep 523
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers) 2014 M235i MT, BSM, MPE, Dinan Springs (Sold) |
Tags |
9.5, fitment, v703, vmr, wheels |
