03-26-2018, 08:02 AM | #397 | |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
03-26-2018, 08:05 AM | #398 | |
Rep 1,161
is it because a front 8.5 x 19 with a ET 35 running a 235/30 tyre is pushed further out by 5mm than a ET 40? EDIT: just done a check - because off the overall diameter. with a 225 tyre you only gain 1.45mm in ride height - with the 235 you gain 4.95mm
2014 M5
1990 E30 318i Touring 1999 E38 728i -sold M235i - sold Activehybrid 5 - sold |
03-26-2018, 09:30 AM | #399 | |
Rep 1,303
However, the cross section can be distorted slightly by mounting it on a wider or narrower wheel. That’s how you get stretch tires on wheels. Yes, a 8.5et35 pokes 5mm more (further from the suspension) than 8.5et40. With an 8.5 wheels, the maximum offset before rubbing on the strut is ~39-40, depending on who you ask. The issue with using an 8.5 wheel up front, even with a 39-40 offset, is that a 225 tire is stretched, therefor has more clearance to the strut (tire doesn’t bulge) and the inner fender. With a 235 tire, it’s not as stretched so you lose clearance on both the strut side and inner fender. On stock suspension, this isn’t a problem utilizing a 235 tire on an 8.5et39-40 wheel. When you lower on springs only, you get ever so slight camber, but not enough to clear the inner fender during turns. If you roll the inner fender, you MIGHT be able to clear when turning, but if that turn also has a bump then you will rub, possibly damage your fender. If you use camber plates or coil overs with camber adjustment, then you can camber enough to clear the fender. Camber is caused by tilting the strut in, which in turn pulls the top of the wheel in (where the rubbing would occur without camber). This is why camber creates clearance for the 235 tire mounted on an 8.5 wheel. |
Hasser446.50 |
03-26-2018, 09:48 AM | #400 | ||
Rep 1,161
makes sense now.
2014 M5
03-26-2018, 10:45 AM | #401 |
Rep 1,303
03-26-2018, 05:43 PM | #402 | |
General
2042
Rep 25,989
Hopefully someone who has run similar fitment can chime in!
VMR|Wheels | 714.442.7916 |
Hasser446.50 |
03-27-2018, 02:38 AM | #403 |
Rep 1,161
just read the whole thread again
I see you are running a 235 front and 265 rear on the wheel specs i'm looking at. how you finding it - any modes needed? alignment change? probably play it safe and go 225 front and 255 rear though.
2014 M5
03-27-2018, 03:29 AM | #404 |
Rep 1,303
I’m on stock suspension so no rubbing issues. Didn’t need to roll fenders or anything. I went 235/265 because of xdrive. It’s a closer rolling diameter than 225/255. Oh and no I didn’t need to realign or anything. Car drives straight every time. Only thing I’d change (now) is the DWS tires. They’re great, but I live in Florida now. Would like to get some PS4S for better grip
03-27-2018, 03:37 AM | #405 | |
Rep 1,161
2014 M5
03-29-2018, 08:01 PM | #406 | |
Rep 138
And would this same setup work with 18s no modifications??? |
03-29-2018, 09:07 PM | #407 | ||
Rep 2,364
Follow my builds:
Acalamito32129.50 |
03-30-2018, 12:28 AM | #408 | |||
Rep 138
So you'd think I'd be fine taking off the spacers tmm? Because as of now there's ridiculous poke |
03-30-2018, 12:31 AM | #409 | ||||
Rep 2,364
Follow my builds:
Acalamito32129.50 |
03-30-2018, 12:32 AM | #410 | |||||
Rep 138
03-30-2018, 12:34 AM | #411 | ||||||
Rep 2,364
And if you do happen to need a bit of spacer just get a thinner one.
Follow my builds:
Acalamito32129.50 |
03-30-2018, 12:57 AM | #412 | |||||||
Rep 138
I think pep boys was just being paranoid or didn't know |
abirmaher842.00 |
03-30-2018, 08:40 AM | #413 | ||||||||
Rep 2,364
Follow my builds:
Acalamito32129.50 |
03-31-2018, 09:45 AM | #414 |
Wingman
111
Rep 244
Garage List 2014 BMW 328d xDriv ... [0.00]
2004 BMW M3 Vert [0.00] 2007 bmw x5 [9.00] 2009 BMW M5 [0.00] 2014 BMW 335i xDriv ... [0.00] 2005 Honda Civic ex ... [10.00] 2014 BMW M235i [10.00] 2003 Mercedes Benz ... [0.00] |
Hey guys just got a set of 19 vmr 801s in anthracite with ps4s, love them!
Running 8.5 et35 and 9.5 et45 with dinan springs tire sizes are 225/35/19 255/30/19
2014 F22 M235i
2014 F30 335xi 2014 F31 328d // 2016 F85 X5M 2009 E60 M5 // 2004 E46 M3 2019 G05 X5 50i // 2017 Alpina B6 Gran Coupe |
04-02-2018, 05:36 PM | #415 |
Rep 170
Can I please get some pricing for the below specs shipped to 98106? Are there any discounts to forum members versus buying through ebay etc...?
v801 Titanium Black Shadow Front - 19x8.5 5x120 ET35 Rear - 19x9.5 5x120 ET45 Thanks! |
04-02-2018, 08:03 PM | #416 |
Rep 623
Those look awesome, did you consider a 265 PSS for the rear or was it the risk of rubbing that made you go 255?
04-03-2018, 09:40 AM | #417 |
Rep 1,303
04-03-2018, 02:44 PM | #418 | ||
General
2042
Rep 25,989
PM incoming!
Acalamito32129.50 WillOs7.00 |
Tags |
9.5, fitment, v703, vmr, wheels |
