2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Help advise on brake rotors M235i
      09-18-2015, 09:06 PM   #1
horsepower_and_hounds
Drives: BMW
So i am in the market for some bling and rotors is it's name. Help me deside what is about the best for a daily driver and spirited week end runner. WIll be running low dust semi metalics
So which one?
High carbon cross drilled
High carbon slotted
High carbon dimpled & slotted
Cannot get drilled and slotted.....
I do not know how to set up a poll
      09-20-2015, 10:26 PM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
If you plan on driving hard at all don't get anything but slotted. The drilled or drill/slotted will crack from the heat.
78' Honda CB400A project
      09-21-2015, 09:44 AM   #3
Béhème
      09-22-2015, 05:02 AM   #4
Drives: BMW
I was thinking drilled only....that is what the M's come with I am pretty sure
      09-22-2015, 01:25 PM   #5
allthatisntnow
allthatisntnow's Avatar
United Kingdom
377
Drives: BMW M2C, 991 C2
Drilled = looks only
Vented & Slotted = true performance
Why do F1 and LMP cars run vented only? Because drilled rotors crack under high temp gradients.
      09-22-2015, 09:27 PM   #6
Iceman51sn
Drives: 2015 AY M4
      09-29-2015, 08:47 PM   #7
i8ur911
Drives: F22 228i MSport
As others have said, if it's for looks then cross drilled is fine. If you're looking for performance than you need regular blank rotors......yes, seriously, blank rotors.
      09-30-2015, 02:51 PM   #8
Luminous
Luminous's Avatar
743
Drives: 2019 M5 Competition
Curious to learn more about this, is the idea behind vented and slotted simply an issue of weight reduction or is there another functional purpose?
2019 SG M5C
2015 SO M3 6MT
2015 BSM M235xi
      09-30-2015, 06:59 PM   #9
Drives: BMW
I am surprised that BMW would spec their top models with drilled rotors if they are not as durable, efficient and overall work better. Maybe peeps just buy M's for the looks
I do not plan on tracking my 235 but am ditching the pads due to all the black brake dust so figured I would ad some rotor bling at the same time
      09-30-2015, 07:02 PM   #10
Liquidpaper
Liquidpaper's Avatar
Drives: '15 M235i
2015 BMW M235i  [0.00]
Vented greatly reduces heat buildup, so that is usually (almost always) a good idea.
Slotted is sort of useful. If you are driving in the rain (or snow), the slots help move water away from the pad. It also (somewhat) helps with heat buildup, but not nearly as much as venting the discs. The effect on the structural integrity of the rotor is much smaller than cross-drilling.
Still, if you are driving your car like an F1 or LMP1, then you just want (I think) blank, vented rotors.
