2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB tpms malfunction
      11-09-2020, 07:00 PM   #1
mblaucoupe135
Drives: 2022 M240i
tpms malfunction
I have a 2019 m240i xdrive and got a tpms malfunction message this weekend. it's not the same one you get when one of your tires is low as it won't measure pressure at all. anyone else have this happen? could it be the batteries in the sensors have gone dead? I am currently running a set of 19" vmr wheels on the car.
      11-17-2020, 08:25 AM   #2
MarcoZandrini
Drives: 2018 M240i
I doubt that the battery or batteries have gone bad. Try resetting iDrive.
      11-17-2020, 08:44 PM   #3
mblaucoupe135
Drives: 2022 M240i
how do I do that exactly?
      11-20-2020, 11:42 AM   #4
pmcmtnbkr
pmcmtnbkr's Avatar
106
Drives: BMW M235I
Start the car go into idrive under settings where you check the oil level there is a tpms reset select it and start the rest car must be stopped to activate. Once you activate the reset drive the car status bar will go up until it fails or reaches 100% once at 100% the reset is complete
      12-09-2020, 02:48 PM   #5
2blue
Drives: BMW ’16 228iX
Happened to me around the same time. I chalked it up to the first real freeze. Resetting tire pressure solved it.
      12-09-2020, 08:45 PM   #6
mblaucoupe135
Drives: 2022 M240i
thanks all for the replies. I found out I have a bad sensor in one of the wheels that I need to replace.
