Recommended specs on battery charger / PSU for general use and coding? |
11-29-2021, 10:02 AM | #1 |
Rep 199
I've seen people say to only use a PSU while coding/flashing while others say it's okay to use a battery charger with the correct specs. I already have a portable jump box and a large battery charger/maintainer/jumper but it doesn't have an AGM setting. If possible I'd like to find a NOCO brand which can both supply the correct power to the car for coding as well as maintain and slow charge a battery.
What amp rating do I need for this and is there anything else I should take into consideration? NOCO products are currently discounted for Cyber Monday and if they have one that will work I was going to buy it today. |
12-10-2021, 01:00 PM | #2 |
Rep 1,146
for any serious coding, dont use a battery charger, have been having talks with a tech 2 series are hellish on amp draw, yoiu need a PSU, BARE MINIMUM is 40-45 amps
