2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes M4 LCA+TS fitment issues...
      09-04-2021, 04:17 AM   #1
LanceM26
LanceM26's Avatar
Drives: BMW M235i, BMW M240iX
Hi All,
I fitted the M4 Lower Control Arms and the M4 Tension Struts with the 303 Steel Spacers. I also have TCKline Racing Camber plates and H&R Springs (Red). I am running Apex Arc-8 18x8.5 ET 38 with 245/40 fitted on the car that was fitting fine before doing the upgrade. I am now rubbing what I think is the bumper/bumper guard. Is there any way to fix the caster?
      09-07-2021, 08:08 PM   #2
FaRKle!
Drives: 328d Wagon, M2 Comp, i4 eD35
Either KMAC or SPL caster adjustable monoballs will help you push the wheel back.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      09-08-2021, 02:23 PM   #3
LanceM26
LanceM26's Avatar
Do you have the part number for these? Are they for the M4 TS?
      09-08-2021, 04:51 PM   #4
LanceM26
LanceM26's Avatar
I just realized your link to the channel. I was already a subscriber!!!
      09-08-2021, 05:28 PM   #5
FaRKle!
If using the F8x tension strut arms:
The SPL PN is SPL CRB E9X and the KMAC PN is
193916-6J. If you needed additional spacers/washers to fit the M4 arm into your subframe mount you'd also need them with these monoballs.
If using your stock F2x tension strut arms:
The SPL PN is SPL CRB F3X and the KMAC PN is 193916-5J for your RWD vehicle.
jordan24c128.00
LanceM26115.50
