07-17-2017, 07:36 PM | #155 | |
Reverse Homer
151
Rep 1,064
Did you go to the place I told you to visit? |
K9GunSlinger94.50 |
07-25-2017, 04:32 AM | #156 |
Rep 412
Dinan_Engineering
Hi, I got the dinan mid pipe installed by an authorized dealer a couple weeks ago and was just curious if this was out of the ordinary. I get some metallic clanging noises when I go over bumps or dips in the road like the mid pipe is hitting the cross member or something. I also get a constant blart noise upon cold start up. I can hear the sound coming from below the shifter from inside the cabin. it is only when the car has been siting for a couple hours then when I start the car up I hear it for the first ten seconds and then it goes away. is all of this normal and will go away in time? or could something be loose.. thanks! |
07-25-2017, 09:16 AM | #157 | |
Rep 3,133
10-10-2017, 09:15 AM | #158 |
Rep 474
Dinan_Engineering will the free flow exhaust & mid-pipe be required for install of the Stage 2 Elite (on the m240i), or just the free flow exhaust and in-take? Any idea when the in-take & stage 2 might be released?
10-10-2017, 09:45 AM | #159 |
Rep 3,133
If history is any indication then intake will be required for stage 2. Exhaust will be recommended. Intake/stage 2 will be q1 2018. About as specific as I can get I'm afraid.
10-25-2017, 03:18 AM | #160 |
Rep 412
Dinan_Engineering
I just noticed this as the mornings are getting cooler here, but since installing the Dinan Mid Pipe, all the exhaust fumes are pretty much coming out of my right exhaust pipe. If i put my hand to each exhaust tip, i can feel the heat and air flowing out the right tip while the left tip barely has anything coming out. Is this normal or should i need to take it in to have it looked at? Thank you |
10-25-2017, 08:41 AM | #161 | |
Rep 3,133
K9GunSlinger94.50 |
10-25-2017, 09:09 AM | #162 | |
Rep 303
K9GunSlinger94.50 |
10-25-2017, 09:38 AM | #163 |
Rep 3,133
I just assumed the Dinan axleback was on the vehicle as well but if the stock muffler is in play then yes the valve is at play since at startup only one path is open.
K9GunSlinger94.50 |
11-04-2017, 10:56 AM | #164 |
Rep 474
Just had this installed yesterday, ..... HOLY HELL, the sound, ..... videos do not do it justice, .... anyway, ...... ready for InTake and Stage2 Dinan_Engineering, .... I NEED IT, ... LOL, ..... well, I do not need it, but damn I cant wait until you release it
Dinan_Engineering3922.50 AlexM240i101.50 |
11-19-2017, 07:03 AM | #165 |
Rep 281
Did you have the full Dinan exhaust installed or just the mid-pipe? I'm debating on what to do. Thanks.
11-19-2017, 08:11 AM | #166 |
Rep 558
If you're unsure, you could get the mid-pipe first and then if you're not happy with just that, get the muffler. They don't have to be done at the same time.
11-19-2017, 02:22 PM | #168 | |
Rep 474
Mid pipe and exhaust there are no cuts at all. I am really digging the full replace too, and most likely will keep the car as my last ever fossil fuel burning vehicle
Looking for 335/n54
11-27-2017, 12:39 AM | #169 |
Rep 281
11-27-2017, 09:33 AM | #170 | |
Rep 303
There will be an issue pairing the Dinan midpipe with the MPE since both have the same diameter and the MPE comes with a pre-welded clamp. I strongly recommend taking the car to an exhaust shop to do the labor. |
11-27-2017, 10:53 AM | #171 | |
Rep 281
AlexM240i101.50 |
12-02-2017, 09:29 PM | #172 |
Rep 412
Dinan_Engineering
one other thing i noticed, on cold start up i get a very loud metallic tinging/tapping for about 10-15 seconds and then it goes away (sounds like its coming out of the left exhaust).. normal as well? |
12-04-2017, 09:56 AM | #173 |
Rep 3,133
Shouldn't be. Sounds like something is hitting and once it gets hot the exhaust is growing away from whatever it is hitting. Should take it back to the installer to check out but again it sounds like its probably a clearance issue and just needs to be adjusted slightly.
K9GunSlinger94.50 |
12-08-2017, 10:48 AM | #175 |
Rep 912
I had the same issue - a little rotation of the pipe solved it.
K9GunSlinger94.50 |
12-12-2017, 11:57 PM | #176 |
Rep 120
Drives: 2018 BMW M240i
I got this installed on Tuesday, and for the most part, it sounds awesome. I've noticed that under hard braking though, there's a rather noticeable vibration/buzzing sound audible in the cabin. I'm assuming that's not expected... any tips on what to do to fix it? My first thought is that there's not enough clearance between the rear midpipe and the cross member, but I wasn't sure why it was only making this noise when braking.
