04-10-2016, 10:39 PM | #133 |
General
10445
Rep 40,778
Drives: 2018 Alpina B6 650ix GC
So long as you do not have ENTRYNAV or EVO Head Unit, it works.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
04-11-2016, 08:59 AM | #135 |
General
10445
Rep 40,778
Just display your current Map version from iDrive Option Screen, and if it is not ROUTE or EVO Map, you are good to go.
04-22-2016, 02:46 AM | #136 |
Rep 12
I suppose that I can use this command also for my Mini that has an NBT system.
But I should change my region (Europe). So what is the correct parameter for me (europe region, and map europe next 2016-2?) Thanks a lot |
04-22-2016, 04:45 AM | #137 |
General
10445
Rep 40,778
Use 0xA9 0X27.
05-15-2016, 04:46 AM | #141 |
Rep 242
Hi to everyone!
I update my bmw 320d touring F31 with 2016-2 Europe Next (Nbt) with the code : 0xA9 0X27 I have a question: When I will to do the next update I'll have to redownload the file DE.fsc or I can use the old file? Thanks , have a good day |
05-15-2016, 06:09 AM | #142 |
General
10445
Rep 40,778
Same DE file.
05-16-2016, 02:46 PM | #143 |
Rep 2
Hi,
I have F25 from 2015 and when I try to update the map 2016-1 or 2016-2 europe next after confirmation of update availability (Start Update) it's give me the following message: "Please insert USB 1'. I have a 32 GB USB and I copied all the files on the USB root folder. Could you please help me? |
07-14-2016, 08:15 AM | #145 |
Rep 3
2016 - 2
So I just bought an FSC code to do the update, I live in West Europe (Switzerland), and Europe comes in 2 parts now "East & West".
Anyway, I used the code to update West first since I live there ( it asked for a code to update) and the next day I decided to update east Europe as well, I was not asked for a code this time and I don't know why! The question is: does it matter which part (East & West) I update first? or both are fine? cause now when I check the Maps version is says "2016-2 Premium - East! Thanks! Last edited by amd.waheed@gmail.com; 07-14-2016 at 08:30 AM.. |
07-14-2016, 08:19 AM | #146 | |
General
10445
Rep 40,778
07-14-2016, 08:32 AM | #147 | |
Rep 3
so this means since I live in West, I keep west for now, but if I plan to go east, then I need to install east? Thanks |
07-14-2016, 08:34 AM | #148 | |
General
10445
Rep 40,778
If you care only about the main roads, then you should not have to switch maps.
07-14-2016, 08:39 AM | #149 | |
Rep 3
Thanks! |
07-14-2016, 08:41 AM | #150 |
General
10445
Rep 40,778
Correct. If both maps could fit on CIC Hard Drive at same time, then BMW AG would have no need to split them up to begin with.
