2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack M235i wheel offset
      05-15-2014, 03:24 PM   #1
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Has anyone actually look at the wheels offset (those that took delivery)??
Seems like this info is top secret still
*Edit*
stock M235 specs (thanks to 2blue4you)
7,5JX18 ET:45 8JX18 ET:52
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      05-15-2014, 04:01 PM   #2
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
Yeh I'd like to know the 19" wheel offsets also
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      05-15-2014, 04:30 PM   #3
scrape1
Drives: '14 228i M Sport, '04 X3 3.0i
These are 19" accessory wheels
Offsets are the same for 18" and 19" ET45 front, ET52 rear
Doesn't seem like you can do too much width wise with the car. I got some 8.5s in the back now, and it doesn't look like you can go a whole lot wider without something rubbing.
      05-15-2014, 06:20 PM   #4
phoenixbmwlife
19 X 7.5 et 45 and 19 X 8 et 52 is rather small. Looks like our car won't be able to wear a 275 width in the rear. I really don't like how thin the tires are on the car. I think BMW should have designed it to be a bit more flexible. Guess only the M2 will have that availability.
Follow me on Insta
      05-15-2014, 06:22 PM   #5
cbbplanet
Drives: space shuttle
i'm ok with a 265 on the tires.. i was even stretching on a 255 tire with my e92.
      05-15-2014, 07:23 PM   #6
phoenixbmwlife
265 rears will be fine I agree. My old Z4 coupe had 275 and I just loves the stance from the back. Was hoping that the m235i would have a nice wide stance also. 265 will suffice but I doubt it will fit.
Follow me on Insta
hatuey0.00
      05-15-2014, 07:41 PM   #7
scrape1
Tire rack does sell some 9" fitments for the back wheels.
http://www.tirerack.com/wheels/resul...rSpecial=false
But only 245 width tires on those. A 265 tire should fit on that rim, but it might be that the wider tire will rub something. I know there is not a whole lot of fender clearance with my 245 tire on 18x8.5 rims.
      05-15-2014, 08:20 PM   #8
BLK235iNJ
BLK235iNJ's Avatar
183
Drives: m235i,13MustangGT,84C10,99A8
rears are 52.... don't remember the front. I spent all week at the wheel shop trying to figure out what 19" wheels will fit the car without having to purchase a 2 or 3 piece wheel.
The high offset made the selection pretty slim. I was told that if I want any type of concave or deep lip I'd have to go fully custom 2 or 3 piece.
I'll post the exact specs tomorrow.
      05-15-2014, 08:21 PM   #9
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
52 rear...thats some pain in the balls offset
2006 325xi (Sold)
      05-15-2014, 08:27 PM   #10
BLK235iNJ
BLK235iNJ's Avatar
183
ended up going 19x8.5 all the way around with 225/35 front and 255/30 rear. We played with the offset to give it a staggered look.
      05-15-2014, 08:54 PM   #11
basiluf
Drives: 2019 S450 2018 S90
pics please??
'14 M235i(current)ED
'11 E93 M3(past)ED
'08 E90 328i(past)Local
      05-15-2014, 08:58 PM   #12
BLK235iNJ
BLK235iNJ's Avatar
183
Hopefully next Wednesday I'll have them installed (ordered).
      05-15-2014, 10:34 PM   #13
TB///M3
Drives: 16 ///M3
Here is the stock M235 specs.
      05-16-2014, 09:32 AM   #14
basiluf
Does anyone know the weight of the stock wheels?
'11 E93 M3(past)ED
      05-16-2014, 12:35 PM   #15
cbbplanet
time to be the first one to get that wide rear body
      05-16-2014, 12:36 PM   #16
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Thanks
Will add on top for others to see
2006 325xi (Sold)
      05-16-2014, 03:43 PM   #17
BLK235iNJ
BLK235iNJ's Avatar
183
who makes it? I would definitely do it.
      05-16-2014, 05:27 PM   #18
daisy16905
Drives: 2014 M235i
Thinking of putting factory 245's on front and running 255's Michelin Pilot Sport's on back with factory 7.5" & 8.0" wheels. What does everyone think?
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
      05-18-2014, 02:17 AM   #19
cbbplanet
LTBMW in Los Angeles. Just gotta ship your car here since its requires some cutting and drilling
      08-11-2018, 10:33 AM   #20
saadams95
Drives: 2020 F87 M2C
2016 BMW M235i  [0.00]
M235i Offset
Can you do a 18x9.5 ET35 without any rub? I haven't seen this as a setup in all around. I've seen the 18x9.5 in the tears but not the front. I've been told it won't work
Or does it have to 18x8.5 all the way around? I have x drive so I don't want a staggered setup. Want to be squared up.
Was looking to do this....
      03-06-2023, 02:32 PM   #21
Falco_666
Falco_666's Avatar
18
Drives: ///M2 Competition
Can someone confirm it this would fit on my M235i?
8J ET30 on all 4 corners, 19" wheels.
Stock tire dimensions (225/35R19 and 245/30R19) lowered on ST XA coilovers.
Thank you in advance.
