2Addicts | BMW 2-Series forum Technical Topics Wheels and Tires -- Sponsored by The Tire Rack RDC Location for TPMS
      01-22-2023, 02:04 PM   #1
OakDan
Drives: Z4 sDrive35i
No recent changes to my car but I just started getting a failure with the TPMS. If I try to reset it, then it will slowly go to 49% and then just report a TPMS failure.
I checked with a TPMS scanner and each wheel's sensor is working and reporting correctly. I'm guessing the RDC box could be bad but not sure where that's located in the F23.
Anyone know where to look for it?
      01-23-2023, 01:12 PM   #2
WolfGTI
WolfGTI's Avatar
2002 MINI Cooper S  [0.00]
2015 BMW X1  [0.00]
Did you scan your car for codes or faults?
Rogue Engineering SSK & transmission mounts, WaveTrac LSD.
Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r).
      01-24-2023, 01:17 AM   #3
OakDan
Yeah, there's a fault with the REM - Rear Electronic Module that is persistent. Code is 80482E which says "Wrong HW version.
Everything else works though and it's just the TPMS that isn't working.
      01-24-2023, 07:54 AM   #4
WolfGTI
WolfGTI's Avatar
2015 BMW X1  [0.00]
Here's a thread on the same fault - but may not pertain to you with the wheels sensors:
https://f30.bimmerpost.com/forums/sh....php?t=1560256
