10-18-2021, 05:39 PM | #1 |
Rep 1,146
AGM battery questions
is there a standard for charging and checking AGM as opposed to wet cell
in so far as base trickle charger is 4.3A at 14.something can I use a 5A or even 7A charger ? was told somewhere you shouldnt use over 4.3A also on putting a maintainer, for simple coding (such as bimmercode) I don't think a 4.3 is man enough , is a 5,7 or even 10 ok (istap warns if your voltage is too low) Also what should a standing voltage be on an AGM, 12.6 is lead, I'm reading again, should be higher, sorry finally, not to be charged at under 0 deg's ? again all info I googled up, before I came here txs again Relevant to all my other threads but I wanted to keep this very specfic txs |
10-18-2021, 08:21 PM | #2 | |
Rep 5,262
nazali1309.50 |
