2Addicts | BMW 2-Series forum Technical Topics Cosmetic and Lighting Modifications 228/F22 Tail Light Stubborn Condensation
      06-14-2021, 07:48 AM   #1
ZGadson
Drives: 2016 BMW 228i
I recently had to replace both tail lights on my '16 228i due to condensation that was so bad it caused the connector to corrode and short circuit the entire tail light board on both sides. One right after the other.
I replaced the lights with used assemblies from Ebay and everything works again, but despite ensuring that seals are tight and there was no condensation inside to start with, there's more condensation inside than was even in the original tail lights. I know this is an issue that BMW would remedy under warranty, but mine ended long ago so I'm at a loss.
Fog light condensation has also been an issue since I had to replace my front bumper (long story short, ended up with an M-Sport bumper kit and had it painted to match), but this is surely out of warranty as well.
I've heard you can buy new tail lights from BMW and they'll reimburse you whether or not you're still under warranty, but it's all subjective so I'd rather not spend $1000+ and cross my fingers that BMW will cut me a check.
That said, has anyone successfully dealt with condensation like this on their own outside of the dealer? Could really use some advice. My car looks horrible and it makes me sad.
      06-14-2021, 08:05 AM   #2
KennyFSU
KennyFSU's Avatar
1104
Drives: Lexus RC F
I was able to fix my pre-LCI taillight condensation issues pretty easily. I opened them both up and used RTV blue silicone sealant and applied it along the entire rubber gasket. Let it dry for a few hours and re-install. No issues and it's been over a year.
Estoril Blue E36M3
Mineral Grey M235ix/12.02 @ 115
Ultra White Lexus RC F
      10-10-2021, 12:52 PM   #3
POMFKIMOCHI
POMFKIMOCHI's Avatar
Drives: 2017 M240i 6MT/RWD EBII
Did you happen to take any photos of your work at the time? Would just like a visualization. Thanks in advance!
Modlist
VRSF CP & Catless DP, CTS Intake, BM3 Stage 2 91 OTS, Customized M2 Exhaust, M Performance II Wheel, Shifter and Handbrake; Matchup7 Amp, Dinan Lowering Springs w/kit,
Red Cerakoted brake calipers, Gtechniq CSL and EXOv4 + BeadMaker, Stance SF03 Gloss Black - Machine Tint (F:18x8.5 ET35 (BFG SC2s 235/45/18) // R:18x9.5 ET45 (BFG SC2s 255/40/18))
      10-12-2021, 09:12 AM   #4
KennyFSU
KennyFSU's Avatar
1104
Drives: Lexus RC F
I only have this one but you can see where I applied the blue RTV sealant.
Estoril Blue E36M3
      10-12-2021, 02:39 PM   #5
Mogki
Mogki's Avatar
Drives: BMW 230XI
I had the same issue, thankfully warranty replaced it but the guys that took the car said that's a pretty common fix to put new sealant
