2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes KW clubsports, inside clearance & wheel setup
      10-09-2015, 03:50 AM   #1
geonutt
Drives: m235i
I know with other bmw's you loose inside clearance with KW clubsports. Is anybody running them on their 235? If so what wheel setup are you using? Please include rim size/offset, tire size and brand and whether you are running spacers. I am hoping to run square 245/18. Thanks!
      10-09-2015, 04:36 PM   #2
TreDirtyFive
Drives: X3 M40i
will these work with VDC or is it a delete/box
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
      10-12-2015, 08:10 PM   #3
i8ur911
Drives: F22 228i MSport
This is fully dependent on the wheel size and offset.
I just installed a set of Bilstein Clubsports. I still needed a spacer to fit me Apex 18x8.5 et45's. I also run a 245 square tire set up.
