01-19-2019, 03:00 PM | #1 |
Rep 60
Do you warm up your modern-day BMW before driving off?
The owner manual says there’s no need to let it idle for a minute - just drive away at low RPM. But there's a lot of people who say that warming up the car first is better.
What are your thoughts? |
01-19-2019, 03:12 PM | #3 |
6659
Rep 15,858
01-19-2019, 03:16 PM | #4 |
Rep 1,897
I start the car and drive. However, I take it easy until the car reaches normal operating temp before I push it.
01-19-2019, 04:01 PM | #7 |
European Editor
10589
Rep 22,992
I would warm your car up. Especially in very cold temps. Don't listen to the Interwebs... warm up your car!
01-19-2019, 04:57 PM | #8 | |
BXR
575
Rep 636
and 'warm up' going from 10* to 240* are pretty different scenarios. If it's 10*, I might warm up the car for my own sake, but if it's 60* out, I'm going to let it warm up on the road.
2012 135i M Sport Alpine White
Dackelone10588.50 |
01-19-2019, 05:38 PM | #9 |
2006 TIME Person Of The Year
9720
Rep 6,445
I turn it over as soon as I get in. If it's cold I hit the seat heat with my pinkie at the same time I activate the starter. Then I let her idle while I put my belt on, turn on the audio system, set the navigation (if appropriate) and get my phones set up. After this all is done I drive away.
Answer is "yes" but not intentionally. It's a byproduct of getting setup to drive.
01-19-2019, 05:40 PM | #10 |
Rep 6,934
Drives: 2018 M2 AW DCT
I never warm up my cars. Just start and go. I don’t push it though until it warms up.
floydarogers690.00 Lance_Goodthrust4.50 |
01-19-2019, 05:42 PM | #11 |
Rep 1,303
Drives: 2021 C8 Corvette 1LT
I wait for the cold start to idle down then drive off. While I wait that 15-20 seconds, I buckle, put spotify on, and mount my phone in the holder. Then I drive off. But as others mentioned in the other post, the engine warms up quicker by driving. Also like they mentioned, not recommended to go ham from the get go. Cold cylinder/heads/gaskets aren't as strong to 16psi as they are when warm. Remember, cold things are brittle.
floydarogers690.00 johnnyc42254643.00 |
01-19-2019, 06:04 PM | #12 |
Rep 1,459
Drives: 2023 G81 M3 Touring
Basically I start and drive away.
I start my car, plug my phone in, put my keys/wallet in their respective places, then drive off. My park is three stories up and by the time I get to the swipe sensor to open the gate cold start has finished. Accelerate pretty gentily until oil temp is at normal then enjoy a few higher revs. If the temps were crazy cold like in some places in the world? I’d probably give it more time before setting off, but “cold” here in Melbourne is like 10C (50F), so no need. |
floydarogers690.00 |
01-19-2019, 06:43 PM | #13 |
Rep 254
I don't have any say in the matter. So Cal traffic keeps me under 30mph.
01-19-2019, 07:19 PM | #14 |
Rep 2,404
These days you let it idle for a bit to warm the software up...
01-19-2019, 07:29 PM | #15 |
Rep 442
I typically wait for the initial cold start revs to lower back down to normal idle (~30seconds? I dunno, I've never timed it), then I put it in gear and get moving. I keep mine in the garage pretty much year round and it never gets below 50F in there during the winter, no matter how cold outside it is.
01-19-2019, 07:31 PM | #16 |
Rep 2,294
Once the idle speed drops after a cold start (usually about 20 secs or so), I drive away, albeit slowly at first.
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971. |
01-19-2019, 07:38 PM | #17 |
Rep 2,336
I let the coldstart cycle on my car finish then drive off. Some days the coldstart cycle is longer than others
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
01-19-2019, 08:51 PM | #19 |
Rep 7,433
I start it and let it idle for a minute and a half to let oil circulate and lubricate everything and allow the secondary air pumps to shut off and revs stabilize. Then I reverse the car out of the garage and let it idle for another 3-5 mins before I drive, and I wouldn't push the car hard till the oils temps and water temps hit 90°C (middle of the m2's tenp gauge).
01-19-2019, 09:14 PM | #20 |
Rep 1,561
Always let the cold start function end, then keep the revs low for the first 5 minutes or so while the oil warms up. Seems like common sense.
01-19-2019, 09:47 PM | #21 |
Rep 440
Drives: 2013 335i xDrive
I push Start, Reverse, and the gas pedal to the floor all in one smooth motion.
I'm not completely useless, I can be used as a bad example.
01-20-2019, 02:42 AM | #22 |
Rep 366
Drives: 218i Coupe
Garage List 2020 BMW X2 [5.25]
1993 BMW 850Ci [8.33] 1990 BMW 316i [8.00] 1994 BMW 318i [0.00] 2000 BMW Z3 Coupe [8.83] 1974 BMW Alpina A2 ... [10.00] 1985 BMW 635 CSi [0.00] 2018 BMW X3 [0.00] 1975 BMW 2002 [5.50] 2016 BMW 218i Coupe [8.00] 2006 BMW Z4 M Coupe [8.67] |
I also don’t, I only wait for the revs to go done which is 30sec and then drive off. The main idea of setting off after the revs go down is to let all of the driving components such as the transmission, differential, brakes etc. to warm up together with the engine itself. If you warm up while idling the engine will be ready to give out what it has but other components are simply not ready to handle the load. Also bear in mind that a proper warm up of the transmission is at least 20-25km of driving as the transmission fluid is very hard to heat up and cool down. If you start putting pedal to the metal before that I can guarantee that it will give you headache on the longer run.
