07-10-2022, 03:06 PM | #1 |
Rep 80
Saw MPerformance LSD on eBay $800
FYI. Got an alert Item 115459901127 on eBay. Not my item 6spd 3.08. Part number 33108659987
Seller is in TX Bill I bought new one in Jan. But had st up alert There is another listing for $995. From Canada https://www.ebay.com/sch/i.html?_sop...;segname=11021 |
07-18-2022, 06:26 PM | #2 |
Rep 111
I jumped on the Canadian listing
A lot of back and forth on whether I ordered the right part. Took me a while to be sure I had the right part number for a manual M240i. From the vendor: We use a hollander system so it is a bit different. The part number 33108659987 you are referring to is only a replacement part number that refers to like 10 other part numbers that came before it. We have like 5 of these carriers all from M models. Do you want me to send you the part number before shipping? Also are you simply replacing the carrier with the exact same one you have or are you doing an upgrade. Reason I ask is because we just went thru the exact same thing with another guy so maybe you are trying to do the same thing? The one we finally sent him out was a different interchange but he did order this exact same carrier. We are all just trying to get this right and I only know the part number 33108659987 and that it replaced 33107555610. Any other identifying numbers on the diff I could get pictures of to verify the part? I do not know about replacing the carrier or same carrier different interchange, whatever that means.
Rogue SSK, AWE Exhaust
07-19-2022, 04:02 PM | #3 |
Rep 111
LSD is being shipped. Part numbers match up from the description.
You can search Part number 33108659987 on RealOEM.
