08-01-2020, 06:28 PM | #1 |
Rep 348
91 + Couples gallons of E85 JB4
Hey all! Wondering if it's safe to add 1-3 gallons of e85 to a tank of 91 and if it will successfully raise the octane on the B58. Looking to go with JB4 and 91 is the highest available grade in my area but I have an e85 station nearby.
08-01-2020, 07:21 PM | #2 |
Rep 274
I know some people do this on various 91, 93 octane maps to help improve timing. I haven't tried it, I just run an e40 tune but I would suggest starting with a small amount and seeing how the car reacts. 1/2 gallon to a gallon depending on the quality of your E85.
kianf2264.00 |
08-01-2020, 10:36 PM | #3 | |
Rep 348
MLJR235116.50 |
10-03-2020, 03:26 PM | #5 |
Rep 348
I would try logging map 1 and 2 and deciding after that but map 2 should be fine. You'll get more help with the jb4 on the n54tech b58 jb4 forum. This is an old post.
10-27-2020, 10:15 PM | #6 |
Rep 4
I have done 1-2 GAL fine but nothing more with stock HPFP. You will see fuel pressure drop in the log and car will go lean. But if its easily accessible you should add it with each fill up to help with keeping timing stable. Map 2 was best I could do.
I am pretty sure in the 2 series BMW manual given with the car it states 1-2 GAL of E85 with fill up is okay. I would double check, I feel like when I was doing it, before I upgraded HPFP, I read that and was like, oh cool. Here is link for JB4 forums: https://www.n54tech.com/forums/ Just find B58 and you can post your logs in the "support l go review" |
10-28-2020, 10:31 AM | #7 | |
Rep 190,725
https://www.brewcity**********/about...ol-calculator/ you can successflly raise the octane from 91 to 93 using E85
kianf2264.00 |
10-28-2020, 11:58 AM | #8 |
Rep 8,942
You can also add octane booster to help with the 91... when I ran my Stage 1 wagon NYC to LA certain states we had to use 91. We used Royal Purple octane booster, with that everything ran perfectly fine.
kianf2264.00 |
10-29-2020, 01:35 PM | #9 |
Rep 1,264
I don't think the rubber in our cars' fuels systems is designed for E85. I know BMW and other car companies lobbied the fedgov to not make 15% ethanol as the fuel standard because the fuel systems aren't designed for it. Use an octane booster.
kianf2264.00 |
10-29-2020, 01:37 PM | #10 | |
Rep 1,264
https://www.royalpurple.com/product/...ctane-booster/ |
10-29-2020, 01:59 PM | #11 | |
Rep 8,942
10-29-2020, 03:39 PM | #12 |
Rep 348
I heard octane boosters coat everything in nasty orange stuff. Kinda turned me off using those.
10-29-2020, 03:41 PM | #13 |
Rep 348
Is an octane booster really all that better than e85? There are so many people running e85 without issues. It's cheap and close to my home. The orange stuff that coats the spark plugs when you use octane boosters can't be good for the car, can it?
10-29-2020, 03:48 PM | #14 |
Rep 8,942
I live in PA where 93 is easy to get. My car made one cross country trip and as such will ingest 5 tanks of 91 with octane boost in its entire lifetime. For my purposes I was most concerned with lower octane screwing up my Stage 1 tune and negatively impacting my performance over the course of 1K miles. I don't have a great answer for you simply because it wasn't a huge concern for me, I'll blow it out with a few tanks full of 93 and not think about it ever again.
10-29-2020, 04:58 PM | #15 |
Rep 3,496
Other than CA, was it in the Intermountain West that 91 was the highest octane available?
10-29-2020, 05:23 PM | #16 |
Rep 8,942
I forget exactly but we were relatively good through IL, then hit 93 again in Texas. So if memory serves no 93 in MO, OK, NM, AZ, CA.
dradernh4386.50 |
10-31-2020, 09:45 PM | #17 |
Rep 1,264
At altitudes greater than 5000 feet you won't find much above 91 octane. Why? The air is thinner, less dense. Hence, your engine can't pull in as much air (oxygen) at higher altitudes. The last time I drove across country I drove from San Diego to metro DC. Took I8E to Phoenix and then north to I10E and then north to Flagstaff to pick up I40E. I filled up in Phoenix and noted when I got to Flagstaff that the available fuel octanes were a few points lower than those available in Phoenix.
11-06-2020, 04:35 PM | #18 | |
Rep 4
I do not recommend filling up every tank with it... Only on track/drag days. You can google MMT and find alot of articles of its affects. Also, you will want a Catless DP. |
11-13-2020, 08:37 AM | #19 |
Rep 294
Drives: 2019 M240i Coupe RWD
Our cars are turbo charged and turbos can compensate for the less dense air. NA engines, yes, significant power loss.
