01-13-2023, 04:05 PM | #1 |
Rep 1
Newbie Help Needed - issues with Cruise Control
Evening all, I am a couple weeks into owning my 2015 228i which is factory fitted with cruise control. The issue is, when I follow the instructions to set the cruise control (press the button twice) it doesn't work. A red dot appears on the speedo and a message states that cruise control is ready but the speed isn't maintained.
If I tap the speed control toggle up or down, the red dot turns green and speed is maintained. Is this a fault? I am coming from VAG cars where one press of the button switches it on and sets the speed. Car is under warranty so keen to resolve any issues while its covered. Many thanks |
01-13-2023, 04:47 PM | #2 |
Rep 145
It’s not a fault, that’s how it works. When u press the cruise control, it activates its. You have to press the toggle button up at the desired speed to set it at that speed. From then on you can use the cruise control button to de activate and resume button to resume cruise control. If you press cruise control button twice when it's ON, it switches it OFF.
Hope its not too confusing. Last edited by smanoj77; 01-14-2023 at 11:01 AM.. |
