2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum BMW 2 Series Coupe and Cabriolet (F22/F23) General Forum Remote control
      01-08-2023, 09:10 AM   #1
Dirtybeer
Drives: X4 2021
Remote control
Anyone know where the remote control unit is located on 2series convertible 2018?
Thanks
      01-08-2023, 10:32 AM   #2
jzeiler4
jzeiler4's Avatar
Drives: 2021 M240i xDrive vert
I think it is on the underside of the top cover (rear deck).
      01-08-2023, 10:48 AM   #3
Dirtybeer
Drives: X4 2021
Cheers, I tried that but that ones the gps sender. The one I’m looking for is the key one, the car isn’t seeing that there is a key present and central locking not working from key also.
Thanks though
      01-08-2023, 01:19 PM   #4
freakystyly
Drives: F22 B58 6MT
Various models show the item pictured is where jzeiler4 mentioned...
Minis, I8, I3, SUVs, other hatchbacks.. passenger side rear, near the fuel filler. Above the wheel well.
I can't find a diagram for a vert tho.
      01-08-2023, 01:21 PM   #5
MarcoZandrini
Drives: 2018 M240i
Check www.realoem.com. Enter the last 7 characters of your car's VIN. Click enter and bookmark the page. Group 68 parts are in the audio/navigation section.
      01-08-2023, 01:27 PM   #6
Dirtybeer
Drives: X4 2021
Thanks I tried that earlier and guess what…. No location. I de trimmed the boot and had rear seat out and lhs side panel as I guessed it would be that side as the aerial is. Will try fuel filler side tomorrow.
Appreciate the help . ( the patient with its siblings….)
      01-08-2023, 01:55 PM   #7
freakystyly
Drives: F22 B58 6MT
There's also a key fob detector in the steering column if that is the problem. But the part you have does not go there.
      01-08-2023, 02:05 PM   #8
Dirtybeer
Drives: X4 2021
That bit works ok, if I hold key up to it the car starts. 😕
      01-14-2023, 06:31 AM   #9
Dirtybeer
Drives: X4 2021
Still no luck finding it. Think I’m going to have to go dealers
      01-14-2023, 06:27 PM   #10
jzeiler4
jzeiler4's Avatar
Please do let us know where BMW hid that little buggar.
      01-15-2023, 07:48 AM   #11
cristo
Drives: 2020 M240i Convertible
Right upper trunk area?
      01-23-2023, 11:05 AM   #12
kyo7877
kyo7877's Avatar
No_Country
37
Drives: BMW F22
It’s under rear window shelf
      01-23-2023, 02:23 PM   #13
jzeiler4
jzeiler4's Avatar
No rear shelf on an F23.
      01-25-2023, 05:01 PM   #14
Dirtybeer
Drives: X4 2021
That may be a clue though. I haven’t taken top half of seat out, I’ll try that
      02-21-2023, 07:29 AM   #15
Dirtybeer
Drives: X4 2021
So I’ve found out where it is but I ain’t 100% sure I’m gonna replace it….
Built into the reset seats is the unit that houses the pop up roll bar if the car flips. It’s in there, I’ve also been told these don’t fail?! I’m nervous to take that unit apart. A clue may be that car battery warning came up, I’m going to load test the battery and trickle charge it as I think this may be the cause. The key worked intermittently when I was running it over weekend.
Bear in mind the cars done 9000 miles in 5 years, yes 9k!! The battery may be goosed.
jzeiler4318.50
Search this Thread:
