01-06-2023, 09:30 AM | #1 |
Rep 19
Strut or cover noise?
Had been hearing some noise from the driver’s side front going over tiny bumps, almost plastic-y, as if something’s loose. Took it to the dealership and they said it could be the strut, which run $3000 each for the (2016) M235xi…anyone else face this issue, given they are saying it is fairly common? Being told it’s not a safety issue, just an annoyance so can wait….
Thx.
Thanks,
Talha 2016 M235i xdrive, Esoteril Blue (bone stock, staggered setup) |
01-06-2023, 02:55 PM | #2 |
Rep 218
Since the oem struts are under $350 and
Bilstein are under $500, run away quickly from anyone who quotes $3000 each. |
01-09-2023, 04:15 PM | #3 |
Rep 46
Drives: 2019 G20 330xi, 2015 F22 M235i
what's your mileage?
My 2015 235 needed rears last year at 66k. The fronts are making noise similar to your description - I think it's time. If you're driving Chicago streets in the winter they get beaten up pretty well! I went with BMW parts for the rear, to preserve the suspension modes. |
01-09-2023, 08:44 PM | #4 | |
Rep 19
Will wait and watch for now, the noise is not coming from just the ends either, loose plastic? thanks, Talha |
01-09-2023, 08:46 PM | #5 | |
Rep 19
You in Chicago? If so, what’s your shop? |
01-10-2023, 05:10 PM | #7 |
Rep 46
01-12-2023, 12:31 PM | #9 |
Rep 5,369
Very likely the strut mount/top hat bearing. They wear out and create clunking/popping noises over smaller bumps. Your car has probably had one too many hard impacts on the rough Chicago streets that have over-taxed the bearing in the mount over time. Shocks/struts rarely make much noise as the wear out.
It could also be the sway bar link bearing. That one is an easy test if you can get both wheels in the air to take tension off the sway bar. Simply jiggle the sway bar link for movement. It should tight and no noise. The OEM electronic adjustable shocks are around $350/ea and the top hats and a new spring isolator around $200. After removing and installing springs and shocks a multitude of times on my M2325, I'd have to say doing the work does take a bit more time than most front strut-type suspensions. I can do a side in about 1 hour now in my garage with hand tools. A high quality spring compressor and knuckle separator tool are key to making your life easy. I have can have the rear shocks and springs out/in in around 20 minutes per side. 10 minutes if it's just a shock. Crazy easy.
