01-15-2023, 07:52 PM | #4907 |
Rep 1
Bought it. Well technically I bought it a few days ago, but I just signed up here.
01-16-2023, 09:24 AM | #4909 | |
Rep 1,178
2024 M2
2019 M240i- Sold |
01-16-2023, 09:25 AM | #4910 | |
Rep 1,178
2024 M2
2019 M240i- Sold |
01-17-2023, 09:43 AM | #4911 | |
Rep 1,178
2024 M2
2019 M240i- Sold |
01-17-2023, 10:19 PM | #4912 | |
Rep 213
https://www.2addicts.com/forums/show...postcount=4789 |
JMcLellan2040.50 |
01-19-2023, 02:32 PM | #4913 |
Rep 124
Drives: BMW | B58 F22 || Audi B9 S4
01-20-2023, 05:04 PM | #4914 |
Rep 2,195
qlaval52.50 |
01-21-2023, 11:33 AM | #4915 | |
Rep 160
[Build thread] Mineral White | Cognac | 6 speed | Moonroof deletion
jv92red143.00 |
01-23-2023, 09:19 AM | #4916 |
Rep 1,178
Got the car out of the garage a few days last week and was able to run it out the gas that was a couple months old. With a bunch of rain in MN early last week the roads were pretty clean with very little salt messiness.
Even with running MDH stage 1 91 octane map there is little to no traction in 1st thru 3rd gears, and 4th was a little sketchy at times. I think this is the torque settings by gear with the XHP. I turned the torque limits down and will see how it behaves. Maybe I should revert to stock settings with the tunes for the winter months... I can't wait for the warm spring weather and getting the summer wheels/tires back on.
2024 M2
2019 M240i- Sold |
01-23-2023, 05:03 PM | #4917 | |
Rep 5,369
01-23-2023, 06:52 PM | #4918 |
Rep 38
just done right front wheel bearing on my 2019 230i M sport
got the car last august done alot over the fall and winter all work was performed by me M performance muffler injen intake ftp inlet and charge pipe M2 carbon interior trim xdelete xhp trans tune bootmod3 mg flasher 240i brake upgrade new rotors and used blue calipers evolution raceworks catless downpipe both front wheel bearings to cure humming noise ran 13.2 before removing the cat and going to stage 2 only had intake, xhp, bootmod stage1 with some minor weight reduction, feel that mgflasher is faster than bootmod may have to go to track when it opens to test as i have both licenses want to do lowering springs next may go with dinan's even though the car is xdrive i dont want a big drop also have right rear brake light malfunction usually comes on when it rains goes away on its own might try to repair or replace the taillight Last edited by BHR388; 01-23-2023 at 06:58 PM.. |
01-23-2023, 06:57 PM | #4919 | |
Rep 38
https://www.dinancars.com/products/s...arts/D100-0928 |
01-24-2023, 08:24 AM | #4920 | |
Rep 1,178
I don't know why but for some reason I am surprised by the lack of traction this winter. Must be the addition of the XHP tune and increase in torque.
2024 M2
2019 M240i- Sold |
01-24-2023, 02:48 PM | #4921 | |
Rep 5,369
When temps are below 50 degrees, the only time I give full throttle from the start is in 3rd at around 65-70mph. In 2nd, I have to be rather careful when hitting it from 40mph (~4000rpms). 1st is worthless no matter what.
01-25-2023, 05:09 PM | #4922 |
Rep 140
Put the stock exhaust back on. The muffler delete was fun while it lasted but it was way too loud for daily use.
Upshifting at WOT and decelerating were awesome though. Even with MHD burbles turned completely off, the burbles were still loud and clear but not obnoxious. Car was faster too albeit netting lower MPG. |
JMcLellan2040.50 |
01-25-2023, 05:54 PM | #4923 |
Rep 3,496
I didn't do anything to it. But I did think about driving it again when the weather's nicer, so that's something. I think.
01-26-2023, 08:35 AM | #4924 |
Rep 1,178
This is me everyday. I'm looking at mid to late April here to be able to feel good about putting the summer wheel set back on and having weather where the likelihood of snow is minimal. Hang in there.
2024 M2
2019 M240i- Sold |
01-26-2023, 10:13 AM | #4925 |
3615
Rep 3,585
Decided to make some camber plates, as all the ones on the market had a few limitations that I decided could be overcome to get the best range of movement using stock springs and dampers, but still get a full 30mm of camber change at the top bearing:
14
WolfGTI716.00 jLona24029.50 dradernh4382.00 zoro200122.50 PeanuKeeyes365.50 freakystyly2983.50 E46ZHP254.00 Kernel Kurtz345.00 MLJR235116.50 obhuan22.50 ggggbmw432.50 JMcLellan2040.50 RichardC3003.00 SW111282.00 |
01-31-2023, 07:00 PM | #4926 | |
Rep 160
xdrive = 10% front / 15% rear rwd = 10% front / 27% rear It makes sense that the 230 would have a larger gap because the M2XX is already a bit stiffer (presumably). The 230i photo on their website looks very similar to my 1/2" lowering all around, I say go for it!
02-01-2023, 09:10 AM | #4927 | |
Rep 515
02-01-2023, 11:07 AM | #4928 |
Rep 913
Unless you have timeslips to prove that it was faster, it's all psychological, probably lower mpg due to being driven harder to enjoy the sound.
Rogue Engineering SSK & transmission mounts, WaveTrac LSD. Ohlins R&T coilovers, Turner monoball thrust arms, F87 LCAs, GC camber plates, Superpro subframe bushings, Megan Racing adj. RCAs, delrin differential bushings. Stoptech BBK 6 piston (f) 4 piston (r). |
